Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosh Dishwasher not filling
I'm not exactly sure of the part number but it's a relatively new stainless
stell bosch - my problem is that the washer does not begin filling when I start a wash cycle, instead it just sits there with teh drain motor running and continually drains - when i manually add water it just drains out.
any ideas on where to start to trouble shoot this problem?
Thanks Tom
  • tombarraclou Aug 21, 2008
    Thanks - that makes sense - a few days ago my wife said that water was coming out of the dishwasher - she thinks the waste disposal was clogged so it filled and began overflowing when she drained the sink - I guess the water got into this tray and triped a level switch or something right?
I had the same problem with no water coming in. Each model may be different, but i solved the problem by holding down the clean drain button for 5 seconds. On my model, it is two buttons simultaneously, then closed the door and waited for the washer to cycle through. Once completed, turn off and then back on again to run normal load. If this does not help. Call Bosch Directly. They have an excellent customer service desk (1-800-944-2904) or http://www.boschappliances.com/kitchen-appliances-dishwashers_dishwashers_Integra_800-series.html.
Hope this helps
Posted on Jan 06, 2009
    President:
  • 1,462 Answers
Switch mains off.take front bottom plate off to expose the bottom tray. you will find this is full of water. mop out and appliance will operate. if fault reoccurs, then there is a leak
Posted on Aug 21, 2008
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
How to fix a bosh dishwasher with E 01 code
The E01 error may mean that the water flow into the washer is restricted or that the flow meter is not reading correctly. Sometimes the control board near the washer inlet is faulty and can't read the signal from the flow meter or send that message to the control panel.
First check your shut-off for the dishwasher and make sure that it is open. Next turn the valve off and disconnect the inlet hose. Connect a new hose to the valve and position a bucket under the hose. Open the valve and check the water flow. If you have good water flow, try connecting this new hose to the inlet of the dishwasher. (Unplug the dishwasher. For an under-cabinet dishwasher, you'll need to pull the washer out. Make sure to keep the discharge hose from pulling loose. Then disconnect the old hose from the fitting and connect the new hose instead. Then slide the washer carefully back into place without pinching the hoses or cables.)
If you add a comment with the model number, I may be able to give more specific directions and replacement part information. Of course, if the dishwasher is under warranty, contact Bosch.
I hope this helps.
Apr 12, 2015 | Dishwashers
Bosh dishwasher h23
Please specify the fault seen on the machine
Jan 22, 2013 | Bosch Evolution 800 SHE58C05UC Stainless...
Bosch dishwasher turns on but doesn't fill with water and start washing
There is a float in the dishwasher that sometimes gets stuck and when that happens, the washer will not fill. Look for a (mostly round) upright part that will be in the front of the washer either on the left or right side. That is the float and it could be stuck in the cutoff position (caused by the soap). The older models have it on the same side where the soap is placed. The newer models have it on the opposite side to stop that exact problem. MOve it up and down and clean out any dried caked soap that might be under it.
Good Luck
Nov 19, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dish washer will not fill
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 04, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Rust spots on Bosch STAINLESS dishwasher
Debruce Polish is the answer. It is non-toxic and odorless, DeBruce will remove the rust and pacify the finish. DeBruce is perfect for touch ups and great on ceramic cook tops and more. We buy DeBruce polish at debrucepolish.com.
Jul 28, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher growling and not draining
Bosh dishwashers work off a gravity pump system. They sometimes require a stronger pump. Make sure if it has a air gap either at the top of the sink or johnston T or in the wall that, that is not plugged. They are very sensitive to how the drainelines are set as well. If it was installed prfessionally, call the installer back out as they should warranty there install for 1 year. Also all products have a 1 year MF warranty as well. You should be able to get a BOSH tech out at NO charge to see if it is a deffective pump.
May 04, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosh does no wash dishesses
Do you have any further information? Do you hear the water arms moving? Is this an issue of the detergent, possibly, or is this definitely something with the dishwasher? If it is the latter, I would suggest taking the racks out, and checking the bottom for anything clogging the works. A small lid or silverware may have dropped down there.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
414 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
