Question about Zanussi W1242W Front Load Washer
Washer dryer sticks on j cycle does not spin or drain
My zanussi washer dryer w1242w sticks at j on the dial, it turns during wash cycle but sticks when it gets to j,(it does not spin fast) the water is still in the machine, but the drain pump does not seem to get any power.(the water drains if the drain hose is dropped down).
--the brushes on the wash pump seem to be fine. Thanks in advance if you can help me, mark
  • angler mark Aug 21, 2008
    tried drain pump, all ok mechanically and electrically-sorry should have put it on main post-thanks anyway.i tried all sorts of things --pressure tube,remade all connections etc i even blew out main moter with a small air jet put the machine back together and now works--have no idea which thing sorted it.thanks all for there help
    President:
  • 1,462 Answers
Check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Posted on Aug 21, 2008
SOURCE:
Zanussi zwd 1260w won't drain, no apparent blockages
REMOVE POCKET BY TIPPING MAHINE BACKWARDS. I HAVE SEEN ****** STICKS TO TOYS JAMMED IN POCKET.
Jul 26, 2010 | Zanussi ZWD1260W Front Load All-in-One...
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Changing drain hosezanussi w1242w
It clips onto the pump , you undo the clip remove hose refit and reclip same checking for any leaks before running machine, its very simple to do .....
Apr 13, 2010 | Zanussi W1242W Front Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Will not spin dry at the end of the wash cycle
Check the brushes in the motor. This is a normal problem.
Jan 22, 2008 | Zanussi W1242W Front Load Washer
Zanussi W1242W Front Load Washer Logo
249 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
