Question about Coleman Heating & Cooling
A/C delays coming on when adjusting thermostat
Must adjust thermostat up and down several times to get A/C to come on.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
"Don't worry about this,, this feature was added tothe outside unit to prevent short cycling, like you're doing now.Mr.Rocket Scientist!.
Posted on Aug 21, 2008
Whats happening when all dashboard lights go off on my BMW 745Li eventually comes back on
Changed thermostat? You may have disturbed wiring. I have had a similar problem. Check the device that adjusts the light levels higher or lower. Move higher and then lower a number of times. The moving may help remove some oxidation and help improve the delay in light levels. You may need to adjust light levels later on.
Jan 20, 2015 | BMW Cars & Trucks
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
I cannot get my 1989, 35 hp mercury outboard to idol right. With the throttle onehalf open it will run, but i cannot adjust to idol speed, when i thy to make adjustments it quits. What do i need to do
I just joined here 20 minutes ago...I may be able to help you.
Had similar issues with an old Russian motorbike years ago.
Timing and spark were the solution.
Feeler guages to check space on tappits, disconnect battery first!!
If there is a timing delay / advance adjuster, have a fiddle when its half open, if it dies then you know its working and then adjust back to working. throttle down and try adjusting at idol.
Change spark plug, they can be weird sometimes, look clean and good but still not right.
Come back if that's not it, Dave
Apr 02, 2013 | Boating
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
Why is most everything freezing in my fridge. I have a fridgidaire elite.
Have you tried adjusting the thermostat level down several numbers to see if that solves the problem? It should be on the very top of the fridge portion when you open the door. Sometimes they are located in the freezer but most times the adjustment for fridge is in the fridge and freezer adjustment is in the freezer portion. If that does not work then you could be getting low on freon and it could be super cooling just before it runs out of freon. Try the adjustment first.
May 06, 2012 | Frigidaire Refrigerators
We have a Goodman CKL 3.5 ton 10 seer AC unit. it is labeled Amana Distinction. it is installed in 2006. CKL 42-1L. The problem is that when the wall thermo control kicks on, the fan blows 3 minute of...
Yes there is a way. First You need to see if the outdoor unit has a time delay on it.It would be connected to the contactor and the low voltage wires. If there is not one then there is a problem with your thermostat. If you have the thermostat manual, check to see if there is way to change from the 3 minutes to none. I hope this helps you.
Jun 05, 2011 | Goodman CKL24AR24 Air Conditioner
Does this thermostat have a delayed start setting?
You will have to have the installer manual and go into the con fig settings to change Honeywell.com
Jun 16, 2009 | Honeywell Electronic Programmable...
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
