Question about Samsung CLP-500 Laser Printer
Powerless No power to the printer. Everything seem fine but it look like there is no electricity to the printer. For no reason, it juste don't turn ON. I verifyed the wire, changed it, but still no electricity. Is there a safety fuse or breaker on that machine? Serge [email protected]
  • carlo zanon Oct 27, 2008
    no power, how can I replace the fuse? what is the procedure to open the printer? This is my main problem.
    Thank you for help.
    Carlo
I have same problem.
I found part of my problem.
Fuse 2 (5amp slo-blo) in the low voltage power supply was blown.
Replaced it.
Turn power back on and the component R3 (which is an inrush current limiting thermistor # 10D-13) in the same power supply, blew apart and blew the same fuse.
I don't know if something down stream is causing R3 to blow up or if something is bad in that power supply or I just have a bad R3.
I'm gonna try to get some of the R3's before I do any more testing.
Mjoyce at mindspring.com
Posted on Sep 19, 2008
    Novelist:
  • 217 Answers
There are internal fuses - or it could be a failed PSU
Posted on Sep 17, 2008
SOURCE:
My focus 2.0 TDCI starts good but after about 20 seconds of drive cuts out and stays powerless for about 5 seconds and then suddenly the power returns . When I keep it full of diesel the car is fine but...
I am assuming when you say powerless you mean electrical power so go to your power distribution box disconnect the cable after you disconnect the battery cables clean all connections with oooo steel wool then spray and wipe clean using wd 40 or pb blaster to get all the acid corrosion off then spray the battery post again and the distribution box stud put it back on and tighten then put the battery cables on and make sure everything is tight this should do it the cables or distribution box stud nut if loose will kill all the power after a few minutes because the gap now increases and contact is lost good luck and if this was not what you meant please post back in comments and we'll see what the problem is remember to be specific about the symptoms Stephen
Nov 02, 2017 | 2000 Ford Focus
No power from generator.
Check the capacitor first, then ohm the windings out, do you get any voltage?
Jun 08, 2013 | Coleman Powermate Premium Plus 6250W...
Hp 7500a "The following ink cartridges appear to be missing or damaged"
clean the gold contacts where the ink cartridges seat with alchol and microfiber towel replace ink cartridges.
Jan 21, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
Printing Issue, "Out Of Paper" message
Try to unplug the power of your printer for about 30 seconds then plug it back in.
Also, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Sep 27, 2012 | Lexmark Impact S305 Wireless All-in-One...
My 40 inch samsung tv is only 18 months old and it has literally just stopped working; no electrical power going through the system what so ever?
You can pop off the back and see if the fuses are blown....but samsung tvs are notorious for power problems.......See if its still under warranty.....
Mar 25, 2012 | Samsung LN40B550 40 in. LCD TV
The dryer just stopped running. I check the breaker and everything seems to be fine.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2011 | Frigidaire FER311FS Electric Dryer
Help please - last time I tried to use printer, 'on' light stayed solid green and nothing would work, however after 45mins approx it suddenly returned to normal and printed fine. Now sx115 is...
This could be due to various reasons.
1. Make sure that printer is connected directly to a wall outlet and not to any surge protector.
2.We can perform a cold reset or restore the printer to factory defaults. If the printer is connected to a network then make sure that we make a note of the network settings since the settings will not be the same after performing the reset.
Sep 10, 2011 | Epson Printer Accessory
Samurai runs fine till tou turn on anything
need to make sure the altanatator is working right. might be shorting out while idling ive heard of it before does it do it more when u turn the ac on
Oct 30, 2009 | 1987 Suzuki Samurai
Xbox 360
If this is the same problem I had, mine went for 2 weeks, everyday with me pushing the on button and it stood there like a giant powerless paperweight. Then one day it just suddenly turned on, unfortunately it turned on with RRoD. I'm actually familiar with repairing the RRoD problem, however its been a month now and everything i've tried it just stays on RED Ring of Death.
So sorry this isn't a solution, but if you be patient, maybe yours will turn back on without RRoD
Jul 27, 2008 | Microsoft Xbox 360 Console
Samsung CLP-500 Laser Printer Logo
294 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
