Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Convergance Amp Problem
My samsung HCN4226wx1xaa will not power up with the CG Amp +/_20v plugged in. Unplugging it allows the set to power up with the raster and sound. My schematic of the Sub1 and sub2 bd is not real clear and can't find the signal source that is keeping the power supply from coming up with the board plugged in. None of the fuses are blown from this problem.
Thanks for the help
TheoB
  • theoB Aug 23, 2008
    Thanks for the reply. The new board is on the way, I though maybe you knew what is keeping the set from powering up with the board plugged in. Obviously the sub board is not looking for a signal that the cg bd is working because it will power up when it is unplugged. Figured the cg bd must be loading the +/_20v supply. Not that important, just curious.
    Thanks
    TheoB
  • alex_copley Aug 25, 2008
    from what i was just reading ..i had the same problem...bought new stk's replaced them now it still wont work so this could be the pcb now has shorted out???
  • Samsung Master
  • 8,617 Answers
You need a new converence amp pcb. If you need to know where to get a replacement PCB let me know and I will post a link.
Posted on Aug 23, 2008
  • Sonny Berry
    Sonny Berry Aug 23, 2008
    The convergence board will short causing the set to shutdown for protective reasons,
Samsung Washer Model WF209ANW1XAA not responding to anything. Power comes on but will not operate when pushing any buttons. Will not even allow me to go into test mode.
try unplugging, then while unplugged, hold in power button for 10 secs or so. then plug back in. (if that does not work, try holding in power button while plugging back in) good luck.
Mar 10, 2015 | Samsung Washing Machines
Samsung HCN4226W 42 in.
Try first unplugging power cord for fifteen minutes.
Oct 10, 2008 | Samsung HCN4226W 42" Rear Projection...
How to get tv to allow smart view app connection
Try unplugging power from the wall ,wait thirtysec then plug back in and try
Nov 08, 2014 | Samsung UA40ES6200 40 inches 3D LED TV for...
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
The convergence board has a +20V & -20V input. The +20V is OK, but the -20V measures about 4.5V when the cable is disconnected from the convergence board. I could not find any blown fuses but R858...
Replace R858 and R859...They also go bad frequently when the STK chips fail.
For everyone else...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Feb 23, 2011 | Akai PT5598HD 55" Rear Projection...
Has a bow in it with colors seperate
your comverganc amp have failed they are stk392-110 there are 2 have a tech replace them
Sep 20, 2009 | Samsung HCL4715W 47" Rear Projection...
TV power keeps clicking off and on no picture
Hello,This problem happens when the voltage of pin 1 of IC804 is low. The low voltage is caused by pin 4 not being 20V this is caused by two capacitors not functioning properly ( a 22uf cap in parallel with a .1uf cap) replace these and replace the 24K ohms resistor with a 44K ohms resistor (as per update specs). This should bring pin 4 to 20V and allow the set to activate. Replacing the 24K with a 44K is recommended by the manufacture to prevent the cap from going bad.Or if you do not want to do this yourself have a qualified TV technician do this for you.Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Apr 01, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
No picture on samsung hlp5063wx/xaa
to test this set
unpug the 4 pin conector labeld + and _ 20v on the cg convergence module
if set turns on, the problem is that modual
repaie
replace bolth convergence IC'c stk392-040
also check all 3.9 ohm resistors and both pico fuses.
regards,
daniel.
Jan 16, 2009 | Samsung HCM4215W 42" Rear Projection...
My mitsubishi ws-65809 will not power up.
Mine is doing the same thing. I just talked to the repair guy. It is a power supply problem. Try unplugging it for 5 minutes and turning it back on. Also if you were having problem with any picture issues it is the convergance, and that requires chip replacement. They are estimating $350.00 to replace the power supply.
Jan 02, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
