Question about Insignia IS-LCDTV32 32 in. Television
Insignia NS-32LCD Backlight or Inverter bad???
My TV had been working fine without a problem.  I walked out of my room with the TV running one night and came back to no picture just the blue insignia light on.  The Insignia Logo will be red, I then power it on and it goes blue like normal.  I did the flash light test and did see picture on the screen.  So I know it has something to do with the backlight or the inverter.  Do you guys think it is a failed backlight inverter?  Would this also cause the sound not work?
Thanks
  • mbdawson Aug 21, 2008
    Ok I found where the inverter board plugs into power supply.  It was a 8 pin connector.  The 8 pins were split into 2.  The left side said 24V the other side said GND.  I touched my multimeter positive to a pin on the 24V side and the negative to GND side and nothing.  Could not find any voltage.  Well now this could be a power supply unit problem.
  • Anonymous Mar 30, 2014
    backlight flickering
  • 2,326 Answers
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
Posted on Aug 21, 2008
  • Jaime Hernandez Aug 21, 2008
    Both circuits are using independent voltages. The back inverter board uses +24VDC and the audio circuit uses 12VDC. If the 12VDC are missing, you will not have audio. If the voltage is there, then there's an audio amplifier IC failure.
    There should be 2 pico fuses on the secondary side of the power supply circuit. One for the 24VDC and the other one for the 12VDC line.
The only thing that troubles me is the no sound part. Would a failed inverter board not allow sound?
Insignia LCD TV screen goes black until hit.
Try to follow the inverter to backlight connections---either a loose or damaged plug (look for any plug with tape on it at the plug first) or on the board that powers the lights a bad solder connection or connections where plugs connect.
Oct 29, 2012 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Insignia NS-32E570A11 no picture or sound
Just FYI: I had a friend with an Insignia NS-32E570-A11 with a backlight problem, and it turned out to be one of the actual LEDs in the backlight array was burned out, causing some sort of over-voltage condition that made the backlight sometimes work, and sometimes just flicker for a moment at TV startup and then turn off. We took the panel apart and bypassed the one bad LED (it had a dark spot on it and failed continuity - you can test each LED with a continuity tester and see them light up!), and now the TV/backlight works! Be aware this is tricky bypassing the bad LED, as it is ultrasonically welded to the LED array strip (same technique used to make ICs), so you need to be a very good solderer to bypass it without it breaking the connection.
May 31, 2012 | Insignia Ns-32e570a11 32" Led Lcd...
My tv has sound but no picture, just started happening and its non stop model # NS-LCD37
This one in the pictures has sound and backlight but no pictures due to bad T-CON Bd.
Pictures: http://s807.photobucket.com/albums/yy352/budm/Insignia%20NS-LCD37HD-09/
You need to find out if it has backlight or not so we can figure out if it is power supply, T-CON bd, or backlight inverter board.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find
Dec 07, 2010 | Insignia NS-LCD37 37 in. LCD TV
I have an insignia NS-LCD37HD that has backlight and sound, but no picture. I can tune the tv and hear the channel changing, but get no picture. I don't see any damage to either the main board or the...
Chec to see if you are getting 12vdc at the T-CON board power input pin first.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 03, 2010 | Insignia NS-LCD37 37 in. LCD TV
My insignia ns- lcd22 tv will not turn on when I press the power button the light goes on and stays on but the screen never turns on? How do I fix this? Can I fix this?
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
Aug 06, 2010 | Insignia NS-LCD22-09 LCD HDTV
Insignia NS-LCD47HD-09 power on with no picture are there known issues
Known issue: cheaply made.
Please post back what you find.
Jul 21, 2010 | Insignia NS-LCD47HD-09 47 in. LCD TV
Tv picture will not come on
We need to find out if the power supply is putting out 24vdc for the backlight inverter board and 12~16vdc for sound, look for bad caps with leaking/bulging tops first. If you do have all the voltages then the backlight inverter board may be bad.
http://www.badcaps.net
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Insignia+NS-L32Q-10A+
Jun 14, 2010 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
When I turn my Insignia tv on, no picture shows up. Last night before I went to bed, it worked fine without any problems. My cable in the other rooms work fine so I know it's not that. What could be the...
You could have it in a video modem check that.
Check if you have it on another channel that has no signal.
If these do not work you might just have a bad inverter inside if its under warrenty please take it in and have it replaced/repaired.
if not and you like to repair yourself the folks at www.partstore.com will help you find the part and replace it give them a try if all else fails.
You may want to chat with us about this also only $12.99 one time chat could save you hundreds
thanks and please rate/review.
Aug 19, 2009 | Insignia NS-L42Q-10A LCD TV
Insignia IS-LCDTV32 32 in. Television Logo
2,423 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
