Question about Samsung BN59-00599A Remote Control
My remote is not responding to the tv even i have changed the new baterry
I have one samsung dvd and tv both remote controlers are not responding to the devices
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 21, 2008
Tv not responding to remote
The remote is compatible to your tv? or the infrared is broken.
Oct 21, 2012 | Samsung Televison & Video
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
My remote is not working - changed baterries red light come on - does not activate tv. The spare remote I have does not work either.
its possible that the microprocessor in your tv is out of configuration thus not communicating well with the remote upon a command execution. change the microprocessor and your set will respond
Sep 22, 2011 | Televison & Video
My dvd remote control,turn on and off the tv but not the dvd, so i need to know how to change back to just to operate the dvd, (samsung digital home cinema system) thanks,
hi,
Press the DVD button on the top of your remote to operate it with the dvd player. You remote is multi purpose on you can use it for controlling Samsung DVD and TV. When you press the DVD button it will change to the DVD remote state. When you press the TV button then it will change as remote for the TV. So if yo want to operate DVD with the remote just press the DVD button and if you want to control the TV then press the TV button.
ok
Jun 09, 2011 | Samsung DVD-VR329
I followed the instructions (Brookstone giant remote and Samsung TV) above for manual programming and it worked.... that is it went on. But the volume control doesn't respond and I can't change the...
sometimes there is more than one code that will work for your tv even though its not the right one. Try all the samsung codes even if you found one that worked, try the rest.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Feb 09, 2011 | Brookstone 538744 Remote Control
I have a Panasonic DVD/VCR TV. The remote control works intermittently. Sometimes I can control the volume and DVD/VCR using the remote and sometimes the TV does not respond to the remote. I spoke with...
Do you still have the instruction booklet for the Tv? Find the remote codes and try re-programming the remote. If this still happens try programming an after market universal remote. Hope this helps.
Sep 12, 2009 | Panasonic Televison & Video
Not connection between tv and remote control
try this take the battery out push every button for devices then put the battery back in and see if that works.
Mar 23, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Samsung HT-Q100 - Changed Battery on TV remote control
Just try to clean your remote,this the common problem of dirty contacts of remote it plays a certain unit but to the other won't play.Just open it take a toothbrush with an alcohol brush the remote control board,and dry it for 1minute and close it back then check if working..
hope this may help;
Regards,
VOTIT
Aug 17, 2008 | Samsung HT-Q100 System
Samsung BN59-00599A Remote Control Logo
2,265 people viewed this question
Jerry Greenberg
Jerry Greenberg
