Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
Stand mode only
My tv went off and never came back on after 1 month of purchase, cannot return it from my location so I'm stuck with it. most persons complained about a burnt capacitor which they manage to fix, but there is nothing burnt in my tv. all the voltage points from the power suply board are correct. what could be the problem.
  • lpaul55 Nov 24, 2008
    Finally I have managed to fix my plasma 6842PEM. My problem was the SS (Sustain) Board and not the Power supply. This board is the vertical one to the right connecting to the Screen/Panel. I tested every component on the board and found one of the Transistors on the heat sink was bad, part # 2PG001. This board is made by Panasonic which can be replaced. I got the Transistor which only cost $20.00 including shipping.
    To identify wether this is your problem, disconnect the cable comming from the power board and put on the TV, If the green light stays on then this is your problem.
    Thanks all for your help.
    Laz
  • 26 Answers
The defective capacitor, if that is the problem, is not obvious. But the main power board has a standby mode and an operating mode. Many of the outputs are off in the standby mode. Do the output voltages go on when you press the power button? The tv draws considerable current when the power turns on, about 7 amps, and less then 1/2 amp when off. Do you have a way to monitor the current?
If the capacitor is the problem, it needs to be replaced with one with a Y5P dielectric or it will overheat and burn out again in a short time. Of the main power boards that I had in for repair, about one out of three had a problem other than the burned capacitor.
Posted on Aug 22, 2008
Model TC-P50X5 will not power up. It is 19 months old. The outlet that it is plugged into is live. Removing the power cord and replugging does not help. Comments please.
Is it "leased" or "purchased" from your cable-TV provider?
Big question: does the cable-TV company *WANT* to keep you as a *SATISFIED* customer? If they do, they will repair/replace it. Complain, complain, complain, to them.
Oct 23, 2014 | Televison & Video
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
I just purchased a eepc1001p and it wont boot up its giving a error message saying thatoleaut32dl
Hello.
If you purchased this computer new and it has a warranty, contact your supplier to return it. They should replace it when so new.
If you just purchased the computer from another person who owned this computer and it is no longer under warranty, return to that person, if possible.
If no longer under warranty and for whatever reason, you cannot return this computer and you need to try and fix, try System Restore. Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date several months back.
Hope this helps.
Feb 28, 2011 | ASUS Eee 4G Notebook
I purchased a 32 in. RCA TV/DVD Combo in May 2010. A DVD got stuck in the component and I took it to an electronics repair to retrieve the DVD. They told me that the DVD component needs to be replaced and...
heres the toll free number that I had listed it was good 3 months ago so it should still be a good number. You will have to go thru all the usually press 1's and stuff but eventually someone will help.. Good luck. 1-800-433-8974
Oct 18, 2010 | RCA Televison & Video
Dear Sir, I am in india (chennai ) i bought one dvd on september 10, model DVP 336. When i connect my TV. i am not get colour PITCURE in dvd any DVD my TV IS BPL . and i will give connect the other...
Check your user guide supplied along with your DVD.
Change the settings using the DVD menu. Or return it
to the seller and get another piece. Check at the shop taking a disc
along for checking!
Oct 04, 2010 | Televison & Video
We bought a bulb for our big screen, we have only had it for 7 months. Is there a problem with our television,
No! There is a problem with the LFS4000 lamp that is in it.My first lamp went in 7 months, second lamp in 10 months and am looking at buying a new lamp again, this tv is only 2 years old. Call panasonic 1-800 # found on their website and complain, ask for your complaint to be forwarded to customer relations, you will get a reference # and someone will call you back.Good luck!
Sep 13, 2010 | Panasonic PT-61LCZ70 Television
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
317 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
