Question about Cameras
I tried to download some pictures to my Compaque from my Canon sure shot 400. I could not get them to download and now I get a message in my camera that says "memory card error.
  • cliffaustin Aug 21, 2008
    What is a memory card reader and where do I purchase it. and how do I format the memory card?
    I just need to know where to get a memory card reader and how to use the format option
    Genius:
  • 2,035 Answers
Are you able to see the images in the camera if yes then the photos are in the memory card :
OnCamera LCD screen displays No Memory Card, Memory Card Error,Unrecognized File Format, Incompatible JPEG, or "?" marks for imageswhen card is inserted in the camera or while attempting to Playbackimages. Click here for information on Corrupt images on memory card cause a blank event window
Ifthe camera displays Memory card error, No Memory Card, or takes anabnormally long time to write an image to the memory card, when amemory card is inserted or any of the above error messages, make surethat the card is inserted properly. If this is the case, you may wishto Format the memory card in the camera using the Setup Menu option[Format] as shown below. Please be aware that formatting the memorycard will remove any images currently stored on the card along with anyother data. This can also be caused when images shot with anothercamera are stored on the memory card.
If afterformatting the card in the camera the error persists, try anothermemory card. If this occurs with only the one card it is likely thatthe memory card is defective, if the error persists over more than onecard the camera may require service. If the card appears to bedefective you may wish to contact the memory card manufacturer.
Posted on Aug 21, 2008
  • 958 Answers
Once you plug your usb from your camera to your compaq pc, DO NOT unplug it right away unless you have click the lower right hand corner of the pc that says "safely remove hardware"
if the two components did not communicate well, you can re-try but if you would remove the usb, click first the "safely remove hardware" icon.
then install first the cd of the camera to the pc before downloading pictures.
you have to do all of those things before it would work...
i hope i was able to fix ur problem...
tnx 4 using fixya,
please let me lnow what happened...
drcool...
    Guru:
  • 1,894 Answers
Please use a memory card reader adn then recover the photos from that.
then use a format option to format the card
  • dewan nafees ahmed Aug 21, 2008
    also be sure of formating the card every time you use it fresh in the camera.
    dont forget
    good question.
    memory card reader is a small device used to read memory cards. it is very cheap and handy device that is used by almost every one who has a memory card. you can get it from any electronics shop.
    even canon has its own card readers. you can go for branded ones like canon or else go for any local mode one. both will be good.
    but my suggestion would be.. go for branded.
    and for formating.
    you must find that option in the menu of your camera.
SOURCE:
Window Vista not recognizing my Canon Power Shot A540 to download
I recommend getting a USB card reader for your memory card.
You should make sure that the camera is on for the transfer. If that doesn't work, try another USB input.
Nov 17, 2012 | Canon PowerShot A540 Digital Camera
I have recently shot some pictures with my canon 580 EX flash. pictures seemed to be a bit underexposed. My camera is a 50D pictures shot at ISO 200. The lens was a canon 17-40 F4 L. Is is possible that...
It all depends on the environment you're shooting in. When shooting a wedding reception for instance inside in the evening I will generally use ISO 800 and I quite often use FE Lock which is very handy. FE Lock will pre-flash the speedlite and meter the result based on the center focus point in your viewfinder (it doesn't matter if you have set another focus point it will always meter to the center one so make sure that is over your subject when you use it). To use FE Lock press the button near your thumb that has the * symbol with the center focus point over the subject. You can then re-frame the shot if required and take the picture. The camera will take the picture based on that flash setting and you should find that the shot is better exposed.
Nov 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
LCD picture veiw is runny like a runny film
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 14, 2009 | Canon PowerShot A75 Digital Camera
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
Canon power shot S400
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 26, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Camera froze up Type Canon Sure Shot ZOOM-S
Sounds like the film either didn't advance thru the camera or its been rewound.
Here's a copy of the user manual:
http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Dec 25, 2008 | Canon Sure Shot 105 Zoom S 35mm Point and...
Blurry picture on Canon A80
I don't know what you told that technician, but try this. Download some of your pictures and videos to your computer. If the downloaded pictures look fine on your computer, then the technician was right, and it's probably just a loose LCD ribbon cable connection.
BUT if the downloaded pictures also look blurry with stripes, then it's probably a faulty CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. BUT MAKE SURE you tell the technician this time that it is showing up on your DOWNLOADED pictures. I recommend trying again, and hope for a more knowledgeable tech on the line this time. Please check the following two links for more info:
Mar 13, 2008 | Canon PowerShot A80 Digital Camera
Display problem
Sorry I didn't see this and respond to your post earlier Maxorga. This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free for both of your cameras, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Nov 06, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Cameras Logo
91 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
