Question about Ecoquest Flair Air Purifier
New house off gassing
Does the Flair remove the off gassing (odors and stuff) from new paint, etc in new houses?
You need to be careful of the saturation. It is an electrical apliance and can be a fire hazard if the fumes are too great. But from my experience with my Flair Classic it will diminish the fumes and smell, but will not completely eliminate it. The paint will have to cure. The unit does work wonders on smoke and musty smells though.
Posted on Oct 09, 2008
Just received brand new Austin Allergy Machine Friday April 29, 2011. Funny odor coming out of outgoing air. I have mold, smoke, pet dander, allergies, chemical sensitivities to deal with and I don't think...
Have a Indoor air quality inspection preformed in your house. Then spend the money to have a air purifier installed for the whole house. In this day you often get what you pay for. It may be possible that your Doctor can provide you with a prescripition for the Air purifer to be installed.
May 02, 2011 | Austin Allergy Machine Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
I have just remodeled a old condo with new toilets and I am getting a strong gas smell. How can I get rid of it. I am in Thailand and the building is 22 years old.
Did you connect the sanitary pipe stack to the sewer line that takes away the flushed effluent? Check to see that the pipe is connected, not leaking sewer gas, not plugged up with an animal carcass, and that the pipe extends through your roof three feet past the roof line (keeps smell out of house).
Nov 29, 2010 | Air Purifiers
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
Need To Eliminate Mystery Odor that Causes Alergy Like Problems
"Smokey-acidic" - are you the original owner, and can verify no fires, etc? (People don't always tell the truth when they sell a house).
In my own experience, allergen control is a two-part job
1. Using a purifier/ionizer to oxidize odors and electrostatically sweep particulates from the air (like a magnet in a box of loose hardware - clump the micro-particles that normally float on air currents together so they "fall-out", to be swept, vacuumed or filtered by step #2. My experience is with the EcoQuest purifiers, and I like the ones with needle-point ionizers. I don't have a lot of experience on the RCI technology, can't comment on it. New EQ purifiers run ~$700-1000 USD, depending on capacity; you can probably find used units (older models) on eBay or craigslist for much less, but you'll be doing your own service unless you know a dealer or handyman who will do repairs for you. (and this can get pricey in a hurry too).
2. Use an ultra-high-filtration vacuum cleaner (or a whole-house unit that vents outside/downwind from your house) to remove the "fall-out" and embedded dust/dander/other accumulated crud from upholstered furniture and carpeting. I don't know what kind of "carpet cleaning" you used - some systems just pump hot water into the mud and microbes already in the base of the carpet, **** some of it out, but leave a layer of now-moistened crud in the bottom to grow stuff that you may be reacting to. Some use steam, which is better (kills more of the cooties instead of simply re-hydrating them), others use chemical powders to adsorb dirt and then get vacuumed-out. Just understand, unless the size of the dirt being vacuumed is big enough to be strained-out by the filter media, you'll be inhaling it again when it comes out the back of the vacuum-cleaner, so the really-tiny stuff goes through regardless, which is why you want an ionizer that will clump the little stuff together (and increase the effectiveness of your filter media). Having an external (outside the living space) exhaust on the vacuum would be even better, but probably more spendy and less convenient to routine housekeeping.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using,
Oct 02, 2009 | Alpine Air XL-15 Air Purifier
Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Mar 01, 2009 | Ecoquest Flair Air Purifier
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Jul 26, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL-15 Classic - Foul odor!
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
Jun 06, 2008 | Ecoquest Living Air Classic Air Purifier
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Feb 02, 2008 | Ecoquest Flair Air Purifier
How to Clean The Unit
There is a screw on the bottom of the unit. When you remove it, the whole insides can be slid out. Then just blow the dust off with canned air. Wal la, you're done!
Jan 16, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
98 people viewed this question
Top Ecoquest Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
