Canon PowerShot SD870 IS Digital Camera Logo
Posted on Jun 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I took a video on my Canon Power Shot SD1100 IS, I didn't realize it was in Time lapse mode. Is there a program I can use to switch it to standard mode once it's been downloaded onto my computer?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jun 20, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200988
Points
38521
No. Time lapse takes one picture every whatever interval you set. For example, one picture every 10 seconds. Nothing is recorded for the 9 seconds inbetween so no software program can make up what was supposed to be there.
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
3helpful
3answers
Canon powershot SD1000 video playback problems
Unfortunately, no. Time-lapse video works by taking fewer frames and then displaying them at normal speed so as to give the impression of time going by faster than in reality. Thus, the camera simply hasn't recorded all the information it would have in normal mode, and there's no way to recreate that information. Think of reading just the first line of every page of a book: you'd get through it quickly, but you'd also miss some things.
Now, if you'd shot in slow-motion, then you could throw out some frames until you got to normal speed.
I recorded movie accidently in time lapse mode which is playing it in fast forward mode. I need to convert it back to normal mode. Is there a way to do this? I am using Cannon SD1100
Sorry, it can't be done. The time-lapse mode records fewer images than normal video. Imagine taking one picture every hour out your window. From this collection of pictures you can't see anything that went on between the pictures. It's the same thing here.
3helpful
Viewing my videos
i have good and bad news for you guys. the bad news is that you'll never beable to see those videos in the normal time frame again. but the good news is that there's nothing wrong with your camera. try turning the sd1100 on again in video mode. then press on the function/set button. now just set the capture mode back to standard. you've had it in time lapse. if this doesnt help, then iono.... lol good luck!
Hello I have a Canon Powershot SD1100 IS Digital Elph and I recorded some clips of movies in time-lapsed mode because I didn't realize that it would be fast forward and I was wondering if it could be fixed...
U will have to edit the movie on a video editor ..... Ulead video studio is a good one ....... get ur video on it ...reduce playback speed according to choice and create a new File
15helpful
3answers
Problem w/ canon g9 camera
Make sure that you're not on timelapse, it should be standard to do a regular playback.
Can you switch a video from time lapse mode if it has already been shot?
If anyone can do this, it would take a video production expert that can pull the audio track off and then patch the audio and video track back together. This will require high tech equipment, and quite a bit of expertise to get the two tracks to match. My guess is that this could be done for about $100-200 depending on the expert's rate and actual amount of time they spend on it. Check your yellow pages or the internet for someone in your area that can do this type of video editing.
Good Luck
2helpful
Can I switch a video from time lapse mode after it has been shot?
No. Time-lapse video is recorded at a much lower frequency than regular video. The information between recorded frames is gone.
Imagine taking a picture out of your office window once an hour. You might catch some cars moving and/or people walking, but you won't be able to see what happened between the pictures.
You can go the other way, from a regular video to a time-lapse video by skipping frames. Unfortunately you can't do the opposite without guessing at what happened in between.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
