Windows vista will not load on my laptop - Computers & Internet
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of your computer?
  • 17 Answers
Consider the following scenario. You use the net use command to map a network drive to the Sources folder. Then, you run the Setup program from the mapped drive to install Windows Vista. In this scenario, the installation may not finish successfully, and you may receive the following error message: Windows could not load device compatibility data.
CAUSE loadTOCNode(1, 'cause'); This issue occurs if the Setup program cannot access files and folders that are located outside the Sources folder. The Setup program requires access to these files and folders to successfully complete the installation.
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue, use one of the following methods: • Do not map a drive directly to the Sources folder. Instead, use the net use command to map a drive to the parent folder that contains the Sources folder. • Run the Setup program by using a universal naming convention (UNC) path instead of by using the net use command to map a drive.
Posted on Aug 21, 2008
ICompatability of Windows Vist and my Brother DCP117C
Go to the brother website and download the correct windows vista driver.
Unplug the printer from you laptop.
Install the driver. Wait for the driver to prompt you to plug in the printer and then you should be good to go.
Sep 24, 2009 | Computers & Internet
I need to reboot vista
Do you have a windows restore disk? If you load this you should be able to restore windows to its original state. It will be a rstore cd rather than a windows cd.
Jun 12, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
ABOUT OS...
No it is not if Vista is already loaded. In order for it to work and have a dual-boot, the earlier OS must be loaded first. So, first you must have Windows XP; then you can load Windows Vista; however it does not work the other way around. So if you wanted to have both, you would have to wipe your hard drive clean, load Windows XP, then load Windows Vista....Good Luck.
Apr 09, 2009 | Acer Computers & Internet
Windows vista ultimate
The Best Version of Windows Vista Is Windows Vista Ultimate.
Feb 19, 2009 | Toshiba Satellite A135-S2386 Notebook
Lenovo 3000 Y 410 Laptop XP drivers installation
Dear the drivers which u have for vista for eg LAN / SOUND/ CHIPSET they all are common for any operating system ur load...............so don't take tension install xp & load the drivers.........................Sameeraryan
Jan 17, 2009 | Lenovo 3000 Y410 Laptop
Compaq cq60104TU not loading xp
You cant load xp because it probably doesnt recognize some of the new hardware in your laptop. If vista works, then use vista, if it is too slow for vista, then use vista home basic.
Jan 01, 2009 | Compaq Presario Notebook
Software not loading in my pc with widdows vista
sir, i have a sony handycam [dcr-trv 285e- pal].but problem is software given is not getting installed in my laptop with windows vista. so iam unable to use movie maker trough my computer.so please do the needfull. th
Software not loading in my pc with widdows vista thanking you.
Dec 10, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
