Question about Kitchen Ranges
Need to dismantle an AGA. where to start after switching the gas off?
Try this site for how to e books dismantle move and reassemble your aga
Posted on Jul 28, 2009
Troubleshooting: currently running temp is 10 degrees instead of 3
Switch it off and defrost that patch of ice , switch it on and check temp after a few hours may fix it if thermostat was frozen, if not check for gas leak or faulty thermostat.
Mar 03, 2016 | AGA Refrigerators
Stop my gas aga squeaking
Probably not, but you may be able to replace them. Remove them from the fan if possible, take them to any industrial supply, they should be able to match them up, they usually cost only a few bucks.
Feb 19, 2015 | AGA Companion Dual Fuel (Electric and Gas)...
Smell of exhaust fumes from gas aga
get it checked by a licensed plumber.
You could be subjecting yourself to carbon monoxide poisoning
Dec 30, 2014 | AGA Kitchen Ranges
Aga troubleshooting
contact customer care
Aug 16, 2014 | AGA Kitchen Ranges
Cant keep my gas aga pilot light on keep switching off
The flame supervision device has failed, you will have to get a gas safe engineer out to fit a new on for you
Jul 12, 2011 | AGA Kitchen Ranges
Hi my aga refrigerator has warmed up to 12 degrees i have hoovered all the top vents i do not know how to reset it to a cooler temperature please help
Remove the wall plug for 10 minutes and then plug it back in. If the temperature doesn't start coming down, you need a service call. Most likely cause is the refrigerant gas needs topping up. It can also be that the evaporator is frozen up. That is the radiator type item that chills the air moving through it. It is best to have an engineer fix that as their is always a reason for freezing up.
You need to vacuum the compressor coil fins rather than 'the vents'. The compressor fan draws air through it to cool the refrigerant gas and the compressor itself. You would normally have to remove a vent to get to it. sometimes they are on the rear, sometimes on the top, sometimes underneath.
Go to Bing homepage
Mar 28, 2011 | AGA Refrigerators
I am looking to get an aga cooker instaled gas with my own corgi reg fitter and need assembly instructions
Installation really isn't something that can be done from a set of instructions - it's more complicated than that and needs an AGA trained engineer to do it. Suggest contacting AGA Service for advice, as a badly installed AGA may not function correctly.
Sep 18, 2010 | Ovens
Dismantle rayburn royal
Hi try the aga rayburn wed site for manual .
Jan 25, 2010 | Kitchen Ranges
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
Kitchen Ranges Logo
1,328 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
