I'm working on a Weatherking 10PJA with a 24AH. Is that a muffler or filter/dryer coming off of the compressor discharge line? What type of metering device is on the indoor coil? Thank you in advance for your assistance.
    Champion:
  • 254 Answers
It is a filter, probably to collect either moisture or contaminents. This unit most likley has a fixed metering device oriface where the evaporator connects to the line set.
Posted on Aug 31, 2008
Woods all fridge rp1816rs3. Does this have a thermal expansion valve and where is it located if so
Yes it is called a capillary tube and it is the tiny copper line that goes next to the larger copper lines coming from a discharge filter near the compressor. See the small copper line going to the discharge filter in the photo?
26263504-djvpsmycspjotct0acmvy511-1-0.jpg APPLIANCE 911
Aug 20, 2016 | Whirlpool Refrigerators
We need to replace the compressor but the original compressor is no longer available, zr54ks into zr54kc, we encountered problem on the system, suction:45; discharge:400. Please advice how to correct the...
You have a severe restriction in the liquid line or at the metering device. I assume these pressures were taken running in the cool mode. I need more information to pinpoint the problem. I would not condemn the compressor until i eliminated all the causes for the odd pressures. Did this problem start suddenly?
Sep 25, 2011 | Carrier Heating & Cooling
Hi my Dometic rooftop (1999) used very little worked perfect untill this past year when we went camping. Fan worked ok, but no cold air coming out of ducts. Compressor seems to kick on, or at least a...
Check compressor run amps is correct with a ampere meter. If less, it's under gas leak. Keep your arm on discharge line (smaller pipeline). If no heat means no gas in the system. Find leak and arrest it. Vacuum and recharge gas.Better service the unit and check. Due to condenser & cooling coil, air filter, blower wheel are dust blocked will result to very less or no cooling. Helpful?
Jan 31, 2011 | Dometic Rooftop RV Air Conditioner
Compressor will only build pressure to 75 psi and stop and compressor keeps running what could be wrong
If you can hear air bleeding off through the air filter when you turn it off then the check valve has failed on the compressor discharge to tank line and cannot overcome the tank pressure. If there is no air coming out through the air filter than the intake and dischare valves have become weak or are broken/not seating. Post your findings, I wil see if i can help I worked on compressors for 5+ years
Jan 19, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
I have a goodman CKL36-IH. I was told the windings in the compresser are bad. Compresser runs but dosn't pump.Drawing a vacum,What goodman unit can I replace it with or can this be fixed?
Did you see the guages connected to the system? If the compressor comes on and pumps the line down to a vacuum then the compressor is working. It sounds more like you have a restriction somewhere in the system. Most likely at the metering device or filter dryer. You can use an ohmeter to check the compressor windings yourself. The compressor only has 3 wires, Com(mon), Start, and Run. With the power off connect one meter lead to the Com leg. Next connect the other to the Run leg and read the meter. There should be some resistance there but not a lot. Next connect that meter lead to the Start leg and read the resistance. It should have more resistance than the Run leg but not be open. Next you can connect one lead to the Start and the other to the Run and you should get the sum of the Start and Run readings. Let me know what you get.
Jun 06, 2010 | Goodman Heating & Cooling
Installing compressor 91 civic do the lines have o rings or gaske
this honda uses o rings, these orings should come with the compresor,also you should replace the filter dryer when replacing the compressor,if the compresor locked up you may want to flush the system to get any metal chips out or it will destroy the new one, heres a picture of the filter dryer, its located next to radiator in engine area, good luck,881d179.jpg
Apr 28, 2010 | 1991 Honda Civic
Will it cause a big problem If I install a 2 ton condenser
If is 2ton it'll work fine only it will take a little longer to take out the humidity ,but dont put bigger than that Two ton is 24000 BTU you see in the model number a 24 between all the numbers and letters.
Aug 02, 2009 | Goodman CKL36AR36 Air Conditioner
2 TON WEATHERKING HEAT PUMP VIBRATION AND NOISE.
Your friend is correct. Installing a sump or p-trap in the suction line will probably help. The oil may be leaving the compressor but can't get back.
Feb 23, 2009 | Weather King 10AJA6001AH Air Conditioner
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
