I had a problem similar to this one. The amount of water coming out through the nozzles was much less than it should have been and much of the water was ending up in the tray. I found the problem to be the drainage valve, there was a crack in it. I was able to order a new one - bosch part number 622540 from attached is a picture of the whole unit and also a detail of the split. I did try to repair with super glue but it does not stick to this veryhard plastic
http://www.bosch-home.co.uk/store/product/Valve/622540
cost including postage about 17 gbp
How do you clean inside the nozzles and where is the drainage valve located
Seems like u have clogged nozzles. or you take to the service - it is not expensive and they will show u how to clean it, or clean it by yourself - by opening the side door on the right, unlocking the the locks clockwise and remove whole the black block inside. just wash it under water.
