I have been given the above radio to listen on in my radio shck it works fine but i cannot find the combination to program the channels to work in the 145mhz mode it seems to be stuck in the 146mhz mode would you be able to tell me the button combination to use to put it into the 145mhz band [email protected]
1. Remove battery.
2. Look for memory switch in the upper right hand corner
3. Sswitch this switch to the off position this should erase any settings that may be stored in the radio.
4. wait five minutes then turn switch back on and replace battery.
If you don't have the user manual please email me at [email protected] and I will send you a manaul via email.
Pat N5SLI
THANKYOU FOR YOUR HELP THE SOLUTION SORTED MY PROBLEM INSTANTLY AND I NOW HAVE A RADIO I CAN USE IN THE 145MHZ MODE.
