Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Bosch model WFK2401UC
Displays code (01) and beeps 8 times, any suggestions
    Guru:
  • 1,894 Answers
Please do a hard reset by leaving the unit plugged off from wall power for one night.
Posted on Aug 21, 2008
  • dewan nafees ahmed Aug 21, 2008
    also check the vent. it may be clogged..
    this is actually a fault code error code 1 not one minute check your
    manual as codes different on some machines from memory i think 1 is a
    filling fault this machine uses fuzzy logic if water fill takes longer
    than 4 mins (low pressure) machine stops can be restarted by pressing
    start button.
    see if machine will complete just a rinse cycle.
    good luck
I have a bosch nexxt 500 series washer. When closed it clicks 3 times in series for 3 cycles and then displays e 01. I replaced the lock mechanism with a part directly from bosch and still the same
An answer found on a BOSCH support site said:
"the E:01 indicates a door lock error, make sure the door is closing tightly, you also may have a loose connection on either the door latch assembly or the control board, if these check out replace the latch assembly."
Since you've already replaced the mechanism then it seems possible a loose -connection- may be your problem. If you've already checked all this, please post back.
Jul 08, 2015 | Bosch Washing Machines
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
Dec 11, 2014 | Bosch Washing Machines
How to fix? Dell mini inspiron 10. Its has a 8 beeps. Failure displays.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Nov 09, 2012 | Computers & Internet
I'm in need of carbon brushes for my bosch washer model # wfmc1001uc/07 . Everyone i've talked to said they can't be changed and i'll have to buy a new motor . Can anyone help with a part # or somewhere i...
Hello Max,
I`m not sure how you made out since you posted on here at fixya, but I`d like to offer a solution.
Check out my repair tip, it should answer all the questions you may have or had regarding your post.
http://www.fixya.com/support/r5082734-yes_change_some_bosch_washer_motor
let me know if it was helpful for you please. If so rate it favorably. If not, let me know how I can help.
good luck.
macmarkus :)
Jun 01, 2010 | Bosch WFK 2401
Kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Jun 12, 2009 | Kenmore 82822 Electric Dryer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Mar 26, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
485 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
