Question about Canon PIXMA iP2000 InkJet Printer
Ink absorber I am getting message that my ink absorber is almost full. Do I take it out and wash it or do I have to replace it ? Also how do I remove it ?
It should come out with a little wiggling with your fingers. I replaced mine with a drop or two of glue. Don't use much otherwise you won't get it out next time for cleaning. Follow the reset procedure shown somewhere in this program and it should work. If you let it get "full", the machine will stop printing.
Posted on Sep 22, 2008
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 19, 2012 | Office Equipment & Supplies
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Absorber is full canon mp145
All ink printers clean the printhead periodically by squirting ink through the nozzles, and collecting it in a sponge type area in the bottom of the unit. In the Canon ink printer, this absorber is monitored, and when it becomes full, it gives you the full message. The printer stops to prevent ink from leaking out of it. (HP has no monitoring system, you know you need service when your desk is ruined)
To replace the ink absorbers on this model, it requires that the printer be dismantled, and a good tech will wash everything, replace the absorbers, and reset the counter.
You have a low end model that can be replaced for what it would cost to do this job.
I don't think it's a job for the do-it-yourselfer.
Sep 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have problem with my canon ip1980. the ink absorbent is full
you can open the printer case and look underneth the the ink cartridge ther are 2 ink absorbent foem remove it and wash it until ink remove from the foem make it dry and put it back again.
Nov 10, 2009 | Computers & Internet
How to solve waster ink absorber full problem in canon ip3300
You need to replace the waste ink absorber and then reset the counter. Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Oct 02, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
My canon pixma ip 1600 has a full ink absorber---is there any way to fix this or do i need to buy a new printer-thanks
Try to remove the absorber (wear rubber gloves--very messy) and wash it in hot water and detergent. You can buy the replacement part if you don't want to try to wash it.
Sep 15, 2009 | Office Equipment & Supplies
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Waste tank absorber is almost full ~ message
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Personally, I wouldn't do it myself, I'd inquire w/ Canon about how much it would cost to have it done first...
Maggie B
Feb 10, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA iP2000 InkJet Printer Logo
42 people viewed this question
old marine
old marine
