Question about Acer TravelMate 2355LCi Notebook
Problem with USB Printer
When i plug my USB printer or any USB devices, my notebook doesnt work a.k.a hang. I already did the recovery, still the same. Please give me the solution.
HP Printer Software hangs during install CM2320series-win7-full-solution-AM-EMEA1-v3.1 HP Color Laserjet CM2320nf MFP Saturday 09 November 2013 - 06:09 PM ( Local Time CET , GMT / UTC + 02:00 )...
On my HP i discovered that where i was plugging in the usb at the back wasn't a usb port. Look at the back carefully to see that it is the right port.
Nov 09, 2013 | Office Equipment & Supplies
The cords are all plugged in and computer and printer is on but it wont scan, the computer cannot make a connection to the printer? there is no damage parts or wires.
Check and see if there is a lock button for the scanner,some printers have this feature so that during transportation or moving you can lock the scanner so it doesnt move to keep it from getting damaged,if that is not the issue then i would uninstall the software,restart the pc and then reload the software and make sure to follow the instructions on installing it to the detail.With usb devices you dont plug the usb cable in until it tells you to during setup,thats important,most printers are like that when installing,so if you installed the software with with the usb cable already plugged in then that can be your problem.Make sure your operating system is compatible with the printer such as winxp,vista,win7.good luck
Jan 24, 2011 | Canon PIXMA MP160 All-In-One InkJet...
HP Compaq Presario V6030 usb ports don't work, is this something I can fix with drivers or can they be replaced.
First try these steps
1.Remove all the usb devices connected, then go to device manager and under Universal Serial Bus controlers uninstall all the usb root hub and then restart the computer
2. If it still doesnt work do a bios update from hp.com for your notebook and then restart and do a bios default too.
3. If these steps doesnt resolve the problem do a recovery and even after recovery the NBs usb ports doesnt work then mother board needs to be replaced as the usb ports are fixed in it.
Apr 15, 2010 | HP Compaq Presario V6030US (EZ503UA) PC...
Have an Office Jet 8500 (Ethernet). Printer
if you havent already... try a different usb cord. another thing as well update the usb chipset of your pc... this can be done through the device manager.
another thing to look at is your firewall settings as well whether its windows or a antivirus program sometimes they will block an already connected device unless added to the excepts list
Apr 06, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My pc is showing that the usb cable connected to the printer has malfunctioned or has not been recognised
Simplest thing to try is another USB cable. Still not working, then problem could be in the USB connector on printer.
Possible it could be a conflict with another connected USB device. Try unplugging all USB devices and wait for the PC to drop those connections. You can see these in the Device Manager. Then plug in just the printer.
Oct 22, 2009 | Office Equipment & Supplies
Why is my xp not communicating w/my epson stylus cx9400 fax series. The software is already install but the computer says that there is an undentify device connected to the computer to unplug the device...
try to connect the usb cable into another port on your computer, if still doesnt recognize, you should try it to another computer. if it works, then theres a problem with your computer, if not, you should try to use another usb cable or use another connector like a printer cable
Aug 16, 2009 | Epson Stylus CX9400 Photo Printer
Hp laserjet p2015dn
Turn off the printer and unplug the USB cable. Open up Device Manager. In the View menu, make sure that Show hidden devices is checked. Click on the + sign next to Printers in the right-hand pane. Uninstall any entries for Laserjet P2015. Reinstall the drivers for the printer. When instructed, plug in the USB cable and turn on the printer. It should recognize the device and allow you to print a test page.
Mar 31, 2009 | HP LaserJet P2015dn Printer
Bluetooth not found by computer
Hi Bryan,
if you installed the printer by USB, the computer will have installed the drivers for that connection. ( Although USB is Plug and Play ) I,d refer to your user manual regarding bluetooth connectivity, also your printer.
The bluetooth device ( printer ) usually has to transmit signals, to be detected by the Computer. You,ll probably find that if you enable bluetooth on the Laptop. And turn the bluetooth on the Printer ( if Applicable ) by turning on/off or other function ( sync et,c ) the laptop will sense the Printers signal.
Once you have a communication between the two your setup.
I,d suggest unplugging the USB, as the laptops software/hardware, will assume that the printer already has an adequate connection, and will look no further.
Hoipe this resolves your questions regarding Bluetooth Connectivity.
Mike @ compurepair.
Mar 07, 2008 | Canon PIXMA iP90 InkJet Printer
Will print but won't scan with Vista
go to the system control panel and de install any of this devices drivers completely, unplug the device from the system.
power down the device and the system.
power up the system and device.
after windows is completely started then plug the device usb cable in to the system, do not use a hub, plug directly into one of the motherboards usb ports.
windows vista is supposed to have all required drivers already on board.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&dlc=en&product=79488&lang=en
the link above is hp's site about connecting and testing your device.
if after all this and it still doesnt work try a different usb port on the motherboard and start again.
i have 6 usb ports on my motherboard and my hp printer will not work on the bottom rear port only, it works on all the others, and the strange thing is that everything else i have works with that bottom rear port, just not this printer.
Oct 17, 2007 | HP PSC 2110 All-In-One InkJet Printer
Acer TravelMate 2355LCi Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
