My boiler needs resetting how do i do it? - Heating & Cooling
    Problem Solver:
  • 18 Answers
What specific problem caused it to need to be reset?
Usually just turning off power to the boiler ( switch should be on side of boiler) will resed after no fame sensed.
Posted on Aug 21, 2008
Can you reset the control board or fan on the boiler
Turn power off on boiler would reset it what code are you getting?
Nov 12, 2014 | Trane Munchkin High Efficiency Gas Boiler...
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Nov 13, 2013 | Heating & Cooling
Got home and gas had run out. Put money on and cooker is ok but boiler is still flashing f1. Have turned off the mains no joy. Please help. Have no hot water or heating. Thanks in advance.
you donot say what the boiler is and so help is only a stab in the dark. there is normally a reset button on the boilers ,the boiler recognised the NO GAS SITUATION and shut down, its needs resetting to tell it all is ok now. without the make and model i cannot assist further sorry not enough information.
Sep 06, 2011 | Heating & Cooling
Boiler pressure (steamer pressure) is at 0. Usually, when it goes down it comes back up in few minutes but not today. Also, the water coming out for our espresso shots is not as hot as it should be and our...
Problem is either the element, the pressure stat or the reset thermostat on the boiler left side if the model is equipped with one, has tripped, possibly because the machine is low on water in the boiler or the contacts for the pressure stat are damaged or dirty. First I would check the water level in the boiler then remove the left side panel and check the reset switch and press it in, then turn on machine to see if it heats up. If you do not have a reset switch on the machine then check the element and pressure stat to make sure they are working properly, do a resistance test.
May 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
Will not power on
Hi There is a reset button or buttons depending on the boiler. That may be the problem or if it isn't the reset buttons its the board. If you need instructions for getting into the machine you will need to email me. This one and the next picture is the new style J boiler. The last picture is the old style boiler.
.bansheracer_7.jpgbansheracer_8.jpg The next one is the old style boiler
Jan 22, 2011 | Saeco Vienna De Luxe Espresso Machine
Need to learn about the electrical system. My coffee machine does not turn on,
There are 2 reset buttons on the side of the boiler if you have the neew J boiler.
If you machine is older, there is a reset button in the back of the boiler towards the bottom of the boiler. Push in between the 2 wires on the black thermostat on either boiler. Its harder on the J boiler because the thermostats are between the boiler and the side of the machine.
Oct 01, 2010 | Spidem Trevi Digital Coffee Maker,...
Saeco incanto rondo boiler reset
There are thermostats (2) on the side of the boiler colsest to the side of the machine. There is a reset button on each between the wires terminals. Push both.
Dec 11, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Boiler going into reset I think it could be the thermostat
Changing the t-stat will not keep the boiler from tripping out. Sounds like you need to have the boiler serviced.
Jul 06, 2009 | Desa International GWP20T GLOWARM Wall...
Rancilio silvia
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Sep 08, 2007 | Rancilio Silvia Espresso Machine
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
