Question about Konica Minolta magicolor 2490MF Laser Printer
2490MF I am unable to get this printer to work with a netgear wgps602 wireless print server. I have tried several installs and re installs of both printer and server software. The PC sees the print server fine but I cannot print. I have tried both USB and Cat5 connection to no avail. Also tried fixed IP's and using DHCP nothing works I am convinced there is a problem with printers network port but then if I use a usb in the print server it doesn't print either although it does find the printer but says it has no paper (which it does) spent 2 frustrating days on this and I have been doing IT for 28 years. Any Ideas gratefully received. John K
  • 2 more comments
  • John King
    John King Aug 22, 2008
    Not sure what relevance advice has as printer is installed and working fine on a direct connection. does not relate to my problem
  • John King
    Wireless print server attached to Wireless AP . print server is picked up ok by the network but attached printer not seen.
  • John King
    I do have a cable tester and all cables are ok. printer works fine directly connected. print server is seen by configuration software but although accepts printer it gives a message "No Paper" which is false. thanks for all your advice so far guys, As I said have been IT engineer for long time so please talk as technical as you like. I still lean towards some sort of TCP/IP problem but TraceRt and angry IP show no obvious problems.
  • John King
    John King Aug 26, 2008
    Many thanks for all you suggestions.I have now solved this problem. For some reason after setting up local tcp/ip port if I selected the 2490 from the list of printers it would not work, but if I just picked Minolta network printer all works fine. once again thanks for suggestions.
    John K
  • Konica Minolta Master
  • 1,879 Answers
Checklist:
>printer driver installed at computer
>print server ? do you need to install a computer driver for it? supposed to work independently on the network.
>give the printserver a static IP configure properly the wi-fi or ethernet connection - ping it
>use the printserver's USB (for the printer) port
>delete all the printers icon in your computer
>use add a printer wizard point to the static IP
>open the printer's property page and choose from LPR or RAW
Posted on Aug 22, 2008
  • 928 Answers
There are times when a printer will really not work with a print server. Ive been doing print servers for 4 years now almost everyday and i cant explain it as well. Although the problem happens 90% of the time on multifunction printers. Most likely because they are built to be bidirectional and work best as so while normal printers do not necessarily have to be bidirectional. Although Netgear is not gonna up and say that it does not work. They will tell you first it must be the unit or the printer, everything else other than it just simply aint gonna work.
  • Thomas Lim
    Thomas Lim Aug 22, 2008
    Sample: I tried a 4 units of a Linksys WPS54G on 2 each of 2 different printers 2 works and 2 did not work on all (same model). We did everything we could possibly think of and it still didnt work. Finally i found out it had to do something with the power output of the printer on the USB not being able to reach the print server. Known issue with the printer. So you can check that as well.
  • 6,487 Answers
Is the print server wired to a router or wireless>? if its wireless and you have a wireless router, The only problem there is the wireless settings of the pr9ont server and the router is not matching..
But if the print server is wired to a router, just power cycle the printer server then try to print...
Hopefully your printer and print server are compatible because not printer is compatible with a print server..
Hope that helps......
Posted on Aug 21, 2008
  • Mark Gil
    Mark Gil Aug 26, 2008
    NO problem, good to hera that from you that problem has been solve, feel free to contact us back in the futire for further help...
    Thank you also for contacting us...
    Master:
  • 623 Answers
Start menu
right click my computer
properties
hardware
device manager
?printer
scan for hardware changes icon
  • 19,396 Answers
Check that you do not have a firewall working. Set the printer by inputting the Ip or printer name when installing, do not browse for printer.
  • 1 more comment
  • Ginko
    Ginko Aug 21, 2008
    First ensure that the printer is not faulty by connecting it as a local printer, if you cannot set printer to work as local then the printer may be faulty.
    Once you ensure the printer is working locally disable all firewalls, including router firewall, to understand if it is a firewall problem.
    Use Netgear printer server own software to install network printer, if it can see the printer it should be able to print, unless there is a firewall in the middle, or printer is faulty.
    Check also cables, bet you do not have a cable tester, try replacing them to test if they are ok.
  • Ginko
    Ginko Aug 22, 2008
    If your printer server software can see the Netgear printer server (which is a small router) then you do not need to ping your printer, or traceroute etc., as the printer server is obviously on the network, and is giving out an IP for the printer.
    The first thing you need to do is ensuring that printer is working locally, you told us printer is fine on direct connection.
    If printer is wireless second step is checking that printer is working on network cable connection.
    Connect printer to server using USB, ethernet cable or parallel.
    Connect printer server to computer or router using RJ45 ethernet cable.
    Ensure you disable all firewalls both window firewall and eventual router firewall when you buid your network.
    It will be useful if you can give us a description of your network architecture.
    For example
    Netgear printer server to printer : USB connection
    Netgear printer server to PC : Ethernet cable
    Netgear printer server to Laptop : Wireless
    LAptop to Additional router with WAN (broadband) : wireless
    PC to Additional router with WAN : Ethernet LAN cable
  • Ginko
    Ginko Aug 26, 2008
    Thanks for using Fixya.
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
I have a netgear wireless network. I am trying to
you can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
Sep 09, 2009 | Linksys Wireless-G WPS54G Print Server
Unable to print wirelessly when using Uverse
you can connect your printer directly to the gateway of uverse: or the router of lthe uverse service
Jul 09, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Netgear wireless ps121 won't connect to cannon MFP 4100
Try to disable Zone Alarm temporarily and print.
Also, can you login in to your wireless router and see if print server is on the IP list?
Apr 03, 2009 | Computers & Internet
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Unable to print through the print server
First, make sure that you can print with the printer connected directly to your computer using a usb cable.
- Make sure the printer driver is installed and you can print with a direct connection
- Get the print server's IP Address, NetGear should have already provided you with this info.
- If your'e using windows xp, go to control panel > printers and faxes
- Right click on the printer icon and go to properties
- Click on the PORTS tab
- Click on ADD PORT
- Highlight Standard TCP/IP Port then click on New Port
- Click next
- Input the WGPS606 IP Address
- Print a test page...
-hope it works!!
Apr 09, 2008 | Office Equipment & Supplies
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
NetGear PS121 Print Server won't print out from regular user account
Hello
PS121 isn't wireless, it uses an USB cable to the printer.
Just RUN compmgmt.msc
,find expanding "Users and Local Groups" your kids
/Properties on them
and "Member of" / Add / Advanced / Search /
then select in the list down "Power Users" + OK
Have a nice day. P
Nov 02, 2007 | NetGear PS121 Print Server
Prints part of the page then restarts the print
One suggestions would be to update the firmware of the Netgear Wireless print server Download the firmware for your print server from Netgear's website http://kbserver.netgear.com/release_notes/d102781.asp Instructions for upgrade are on the site! you can also try changing the spool settings, Set it to Print directly to printer RightClick on the printer click on properties and click the advanced tab. Change the spool setting to print directly to printer!! If this doesn't work kindly let me know! regards, babb
May 11, 2007 | NetGear WIRELESS PRINT SERVER 54MBPS...
Konica Minolta magicolor  2490MF Laser Printer Logo
257 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
