Question about Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum
Dyson 07 The roller does not turn. I cleaned hair and string tangled but it still won't turn. How do I check if it is the belt?
  • 33 Answers
Start of by laying the machine on its back unfasten the solepate (which is the cover over the brush roll) as soon as its unfastened it will release with ease then you will see the brush roll with the belt around it simply pull the brushroll out of its position and release the belt from the motor spindal (if attached) and then out your new belts around the slot on the brush roll and feed the belt over the motor spindal (this will be very tough to strech on. Once you have done that out the brush roll back in its position and the soleplate back and you should have succesfully fitted a belt to your dyson.
dont forget to rate this post........
Posted on Aug 21, 2008
Hello! I have a Dyson DC41. It is not working, the roller will not roll, it is not tangled with anything. We took any string or hair that was around the roller.
The Dyson has two belts. One is easy to change, the other is difficult as it is between the clutch.
Turn it over and remove the base.
The other possibility is that you have turned the knob which intentionally stops the brush turning to allow cleaning of hardwood, vinyl and ceramic tiled floors.
The user Guide is here
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/DC41_Manual.pdf
Support and FAQ for problems here
https://www.dyson.com/support/dc41/dc41-irspu
See the videos in the link
dyson dc41 change belt Google Search
Jan 20, 2018 | Dyson Vacuums
Why wont the brushes spin?
Most likely, the belt is broken. I'll bet the roller is covered with hair, thread, string. If brush roller is not routinely cleaned, string, hair becomes rapped around it and makes it more difficult for the belt to turn it. Eventually, the increase in friction and heat weakens the belt and the belt either breaks or stretches out. Try cleaning the rollers and replacing the belt.
Jul 29, 2014 | Miele Vacuums
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why does my Dyson animal DC14 make that horrible screeching noise and how can I stop it? Please!!!! Thank you.
I can't probably help you but I can tell you what Dyson told me. I have this same vacuum and it just started making that same noise. When I called their rep they had me take off the bottom plastic piece (comes off real easy by taking a coin and turning the three circles). Check to make sure the belt isn't broke. Then, they had me pull toward me the roller brush and turn it to get it seperated from the belt. Then, take off the belt. On mine, the spindle was full of dog hair clogging it. I took twizers and narrow pliers and pulled everything off. Then put it back together. It worked fine for the next few times I vacuumed then it started again. So, I did the same thing again and found this spindle covered with the hair again. Cleaned it, put it back together and it worked again. Today, while vacuuming I picked up a piece of string and that noised started again. Turned it over and saw that string on that spindle. Took it off, cleaned it and it worked again then started the screeching again. So, tomorrow I am calling a vacuum repair place. IF you have the same vacuum (which you do) it should still be under warranty. Dyson told me I would have nothing to pay unless I abused the vacuum which I did not. Hopefully I am not without it very long...I have two golden retrievers who do shed alot.
Nov 17, 2010 | Dyson DC14 All floors Bagless Upright...
Hair getting stuck in the belt drive area causing beater to skip
Hair,string, tinsel, etc. have always been problems for rollers and belts. You will have to remove the hair. It can often get stuck at the ends of the rollers also and keep the roller from turning. I usually remove the roller and clean it using a screwdriver, knife, etc. to remove the hair. the cleaning can be done while the roller is still on the unit by turning the unit over although this may not offer as much free access to the roller. Of course, removing the roller means removing the belt and if you are not up to this (I don't know how handy you are), I would try to remove the hair with the roller on. If you do this, be careful not to put any nicks in the belt. Good luck!
Mar 13, 2010 | Dyson Vacuums
Sweeper Brush doesn't turn.
Could be that too much hair, string, or long fibers have been collecting around the roller. Remove it and clean it off. Also check the duct behind roller that goes up into the connection hose. Ther most likely is some sort of blockage.
Nov 20, 2009 | Dyson DC14 All floors Bagless Upright...
Dirt lifter power brush won't move
most likely the small belt that turns the brush roller came off or broke, thi item can be purchased where you bought your unit. also, after you replace the belt, clean out tangled hair or strings that may have caused the belt to go.
Aug 06, 2009 | Bissell 1699N ProHeat Clear View Force...
Dyson make noise after replacing brushroll
Try this open sole plate check make sure belt is not pinched, broken or binding, that thee are no strings or hair between belt & roller,& that belt it is centered on roller.
Be careful & turn roller by hand should torn smoothly except for belt tension.
Also check make sure end bearings are seated correctly. (the parts at the end of the roller where they go into housing.)
Hope this helped. Please rate. If you need more help comment back be happy to assist you further.
Mar 14, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Brush proplem
Hi Dave.
Ok you need to lift belt end of roller up, so that you get the roller straight then lower roller down so that both ends go in at same time down.
Use a large flat screwdriver to help lever roller up from belt end & watch your fingers (Ouch).
http://dysonmanuals.llc.nu/
May 22, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC08 Cylinder Bagless Canister Cyclonic Vacuum Logo
128 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
