Question about Kodak Office Equipment & Supplies
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to clean the print head but it tells me that the operation has failed
    Novelist:
  • 158 Answers
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Posted on Aug 21, 2008
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How do you remove the printer head to clean it?
Regarding your recent inquiry about your MX892 poor print quality/lack of printing performance (or similar), it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer\'s maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color:
1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer\'s control panel under the \'Maintenance\' or \'Tools\' menu, activate a \'CLEANING\' or \'HEAD CLEANING\' to prime the ink system. Then Run the Inkjet411 \'Ink Recovery Test Print\' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
3.Check your user\'s manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges \'park\' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
4.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
      3rd party PRINTHEAD CLEANING solutions (for additional reference only):
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
      http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon Printhead removal / water flush)
      8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
        Typically the printhead should not reach it\'s end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
        Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical \'head strikes\' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
        For any additional questions please contact us directly: Inkjet411help@gmail.com
        NOTE: If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
        -Thank you
Aug 15, 2014 | Cannon Office Equipment & Supplies
The print is faded . ther are three color bar missing on the test page ( yellow, black , and black).
Hi
Go into Maintenance in the Kodak Printer Management Program and try the Nozzle Check and Head Cleaning functions until the Test page prints clearly.
Head Cleaning might be necessary after every cartridge change.
I hope this helps.
Aug 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Constantly cleaning the print head
I feel you should take it back. Under warrantee?
May 01, 2009 | Kodak ESP 5 Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
I900D cannon printer
I was having the same problem and I put the printer through the head cleaning and auto head check and it now seems to be working fine.
Aug 28, 2008 | Canon I900D InkJet Photo Printer
188 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
