Question about Tascam 2488 Portastudio Multitrack Recorder System
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
  • hayden_steve Aug 30, 2008
    Yes, I too, want to get a handle on recording vocal effects on the Tascam 2488 MK 2 portable studio. I bought an effects rack (Lexicon) and I'm still no closer to adding dedicated and verifiable effects during recording. If anyone discovers the method, please post it. Thanks
    Problem Solver:
  • 15 Answers
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
Posted on Apr 09, 2010
Can i use my own electric guitar stomp box to record onto a tascam 2488 neo without miking an amp?
Yes, you should be able to go direct into the recording input if your guitar has a preamp in it and the 2488 may have adequate gain to even accept the input from a passive guitar.
Nov 30, 2010 | Tascam 2488mkii 24 Track Recording...
Tascam234 /casset tape-4 track,
clean the heads, make sure the tape has no edge damage
Feb 02, 2010 | Tascam 2488 Portastudio Multitrack...
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
Recording midi player
Yes. You can record the midi output to a track using bounce mode.
With you midi (or smf) file loaded into the midi tone generator,
press shift-bounce to enter bounce mode. Then arm a track for recording. Turn the fader up for that track, the master fader and the fader for the midi tone generator. Make sure than all other track faders are down or the tracks are muted (or empty) and press play and record. The midi song will be recorded to the track in real time. Just press 'stop' when done and exit bounce mode (by pressing the bounce button again).
bd.
Jan 12, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
How do I connect effects rack (Lexicon) to Tascam 2488 MK 2?
I've got a Lexicon too and I love the thing.
To use the Lexicon as a 'send effect' (which is what it is) you'll need to connect the effect sends from the back of the 2488 to the inputs on your Lexicon. Then connect the outputs from the Lexicon into two inputs on the 2488. Then assign those inputs to tracks.
You've got to select the previously recorded track(s) where you want to add reverb or other effects (by pressing the select key) and then press the 'send' key to get into the 'send effect' screen. Here you can adjust the amount of signal is sent from that channel to either of the effect sends (typically you might want to send one track of a stereo set of tracks out eff 1 and send the other track out eff 2).
Pre, post or off will determine whether the fader affects the signal being sent or not and the loop setting on the top of this screen is for the internal effects.
Once you've got this set up the way you want you just arm the tracks where the Lexicon output is coming into the 2488 for recording, mute whatever you don't want to hear and you can bounce record the raw signal through the Lexicon and record (print) the effected signal on the tracks you've armed.
Hope this helps.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
141 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
