Question about Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch
Chrono hands I replaced battery in my Link watch but the chrono hands will not return to the 12 O'clock position.
  • speltzer09 Aug 28, 2008
    I did not personally replace battery but went to a store different from the one I normally go to. I will go back and see what they will do for me. Thank you for pointing me in the right direction.
    Stan
    Genius:
  • 2,035 Answers
Remove the battery and reset it back and check if it works, if not there could a problem in the watch ,you use this link to get free estimate of the cost repair:
http://www.finewatchmaking.com/
Good luck....
Posted on Aug 21, 2008
  • 6,487 Answers
If you have the user manual for this , you can check the steps that you need to do to adjust it..
Good luck........
    Master:
  • 623 Answers
Try this site
www.tagheuer.com/
    Genius:
  • 3,422 Answers
Please make sure that you have replaced your battery properly.I suggest you t reinstall it once again.
Let me know the result
  • Priya darshan Aug 28, 2008
    Thank you for using fixya.
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
Second hand does not return to zero caliber 3606
Yes, this can be recalibrated from the outside. To get your chrono hands pointing in the right direction pull the crown out to the first position then click the plunger/ chrono button. This should move your chrono hand one click at a time to get it to the right place. If this does not work try pulling the crown out to 2nd position (all the way out) and try clicking the plunger as described above.
If this STILL does not work, which it should, then you'll need to go to an Omega dealer and have them take a look at it.
Oct 19, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Watch not working
Synchronization of the chronograph hand do not affect any watch movement to work properly and it is ment for correct time measuring only.
If your watch does not work properly there is some kind of fault in it and you will need to see a watchmaker to diagnoze it.
Feb 15, 2009 | Cartier Roadster W62019X6 Wrist Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Dec 06, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Problem with the large chrono indicator
Pull out the crown to the #2 position then push the start /stop button to move the second hand up to zero
Dec 09, 2006 | Skagen Men's - PERFORMANCE TITANIUM CHRONO...
Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch Logo
171 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
