Question about Philips Magnavox 52MF437S/37 52 in. LCD TV
Philips 52" LCD TV
I have a 52" LCD and when I change channels it does a little jump on the screen like it try to adjust the picture quility.And when you are watching a program it will do the samething.
  • sspaulding Jan 25, 2009
    I just returned my 42" for this problem and now my 52" does the same thing.  When I am on a non-HD channel and the picture setting is on automatic, the picture jumps like its trying to adjust from normal to widescreen.  My wife thought there was a download from Phillips to upgrade the software but I have not been able to locate it.
I think what you're talking about is the feature of the TV that auto-adjusts the screen for different pictures. What is does is tries to auto-fill the screen in case there are black bars on top (because of widescreen content) or on the side (regular tv content). It does it mistakenly if it notices too much black anywhere... happens a lot to me when credits are rolling. You can turn this off in your TV settings... I think you just set it to a specific type (widescreen, etc) instead of "auto".
Posted on Jan 07, 2010
  • 10,594 Answers
Please preform Auto-Tuning for chanel presets. This problem will be resolve.
Posted on Aug 21, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
How do I fix a black screen with sound working and LED light on.
Unplug the set and let it stand for two minutes. Plug it back in and see if it works. If that doesn't work contact Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 14, 2015 | Philips 42PFL3704D LCD TV
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Pulsing/skipping picture on Sony Bravia 52'' LCD flat screen TV.
Yes it sounds like a lemon. A firmware update is the next thing to try.
Apr 28, 2017 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Philips tv
go in menu and change it to home
May 27, 2009 | Philips 52 In. LCD HDTV
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Every so often, the screen on my philips 42TA648BX/37 tv jumps.
I have the same tv 42TA648BX-37 and it does adjust because not all channels and comercials are widescreen so it adjusts so the picture doesnt look "fat" if you know what I mean. I also recommend checking your software version to se if you need an update.
May 28, 2008 | Philips Televison & Video
Philips Magnavox 52MF437S/37 52 in. LCD TV Logo
310 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
