Look for bad caps with domed tops in the power supply, see example here: http://s807.photobucket.com/albums/yy352/budm/LG/LG%20L1751S/ Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: After monitor is turned on, it goes blank after a few seconds...
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
SOURCE: monitor is going off after a few seconds the power
depends if you can still see the image or not with a flash light.
If the image is there, the is related the back light.
Check to see if any capacitorif bulged o popped.
I just fix one and replaced capacitor, but the CCFl is still bad...
