Question about Mitsubishi WS-55807 TV
Mitsubisihi hd 1080 t.v.
Power buttonm won't stay on
  • Anonymous Aug 24, 2008
    Power button on set and remote will not turn on set. unplug for 15 sec and plug back in and I get 3 green light flashes on the front power light and then nothing...? Garry
  • 927 Answers
Good Day;
Try this when th TV wont turn on:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2.CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 LOCATED OFF PIN 1. (PCB-MAIN) D4000 PART #264P487030 3. CHECK PIN 8 OF IC401 FOR 27.7VDC. IF MISSING CHECK FOR OPEN D955 AND L961 AT S1 TERMINAL OF T902. (PCB-POWER) D955 PART #264P102040 L961 PART #411P012010 4. CHECK FOR DEFECTIVE IC401. IC401 PART #272P239040, OR INSTALL PT# IC-401, THIS KIT CONTAINS CAPACITOR C920, D4000 AND IC401. BE SURE TO MOUNT C920 ON FOIL SIDE OF PCB. 5. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT. Good Luck, big IRISH.
Posted on Sep 26, 2008
The TV will turn on from remote many times and then won't turn on at all from the remote or directly from the TV itself so we end up unplugging the power which seems to reset the TV and then it
Having to unplug suggests a issue where the set is getting confused, if using any kind of box for signal or have a receiver in line remove power from all and after several minutes plug back.
Dec 17, 2012 | Vizio VS420LF1A TV
Monitor won't turn on
Try lowering the resolution on TV and raising on PC. Your video card my not handle HD settings such as 1080 dpi or higher. Also use the best input available on your video card. It goes from VGA to DVI to HDMI.
Aug 31, 2012 | Packard Bell iMedia Computers & Internet
Mitsubishi HD 1080
There are a large number of different Mitsubishi 1080 sets---depending on model number some have a self check which will narrow down where the issue is------even if the set will not come on and stay on.
What is actual model number?
May 17, 2012 | Televison & Video
How do i get my vizio in full hd
Consult the owner manual to make sure the input it is connected to is 1080 and you are on that input-------HDMI? Component? 1080 Component?
Apr 16, 2012 | Televison & Video
The tv i own: Panasonic TX-32LX77 LCD Monitor (TX32LX77) . i want to know if this is HD. if i hook up the tatasky HD box, will i get a full HD output? thnx
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
May 23, 2011 | Panasonic Viera TX-32LX77 LCD TV
I have Mitsubhishi HD 1080 model number WS65315
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 19, 2010 | Mitsubishi Televison & Video
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
I just subscribed to HD service, But my mitsubishi 55807 tv wont display 1080 it stays on 480. the server is comcast. can you help?
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi WS-55807 TV Logo
182 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
