Question about Bosch Classixx WFC 2465 Front Load Washer
Water inlet not filling
Hi all,
The water mains is on.. washing machine beens working fine. Suddenly one day the water does not fill the machine.
I have a Bosch front loading machine, the water normally goes thru the detergent drawer, but after activating the wash cycle, the detergent drawer stays dry and water is not being filled into the load..
Please help!! Thanks in advance..
Cheers,
Perplexed..
  • DIRTYNAPPY Sep 11, 2008
    WATER COMES IN VIA PREWASH DISPENSER ONLY, ONLY FOR A FEW SECONDS, THEN WASHER GOES ROUND FOR 10 MINS, THEN LIGHTS FLASH - RINSE HOLD, START AND 800 LIGHTS... MY WASHING IS STILL DRY AND THE MACHINE HAS BEEN RUNNINGALL DAY!!
    President:
  • 1,462 Answers
Check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Posted on Aug 21, 2008
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Bosch WFMC3301UC washer. The water will not flow into the machine. After a few minutes we see an error msg E02. I had replaced the hot water inlet valve two months ago because it developed a leak. No...
Bosch WFMC3301UC washer. The water will not flow into the machine. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 12, 2011 | Bosch WFMC 3200 Front Load Washer
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
I do not get any cold water.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 15, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water won't fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Nov 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water is no fill in mashine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Works on hot not cold cycle
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 10, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Sep 09, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Bosch Classixx WFC 2465 Front Load Washer Logo
154 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
