Question about HP Office Equipment & Supplies
Printer does not scan to computer - HP Office Equipment & Supplies
  • rawlison Jan 10, 2009
    I am trying to put a picture from my printer to my computer how do I do it.
Do you have the SharpDesk installed? That is required to scan to computer, unless you have it setup to sed via email to your computer.
Posted on Aug 21, 2008
How do set up my lexmark pro901 to scan to my pc so that I can email the scans
Make sure the Lexmark Pinnacle Pro901 printer driver is installed on your computer. If you have the install disc that came with your printer, just insert it to your computer hard driver and follow the instructions on your computer screen. You can also the download the printer driver from the Lexmark website at http://bit.ly/d3ftso. Select your operating system > download > execute the file. Again, just follow the instructions on your computer screen.
Note: The install disc contains the Lexmark OCR scan software necessary for scanning documents for editing and saving them as PDF files. The downloaded driver does not contain the OCR software.
To scan to your computer using the printer operator panel:
1. From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2. Touch USB-Connected Computer or the name of a network computer. The local or network computer is the destination that will receive the scan. Wait until the printer has finished downloading a list of the scan applications available on the selected computer.
3. Select an application (in your case your email), and then touch Accept.
4. Select the color, resolution quality and the original image size. If necessary, touch Accept each time you make a selection.
5. Press the start button to start scanning. The scan is complete when the application you selected in step 4 opens on the destination computer, and the scan appears within the application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1. Click Start.
2. Click All Programs or Programs, and then select the printer program folder from the list.
3. Select Printer Home.
4. Choose your printer from the printer drop-down list.
5. Click Email, and then select Photo, Document or PDF.
Note: You can select Document only if an OCR application is stored on your computer. Scanning starts and the scan progress dialog appears.
6. When the scan is finished, a new e-mail message is created with the scanned document automatically attached.
7. Compose your e-mail message. Note: If your e-mail program does not open automatically, then you can scan the document to the computer and then send it through e-mail as an attachment.
For Mac:
1. From the Finder desktop, double-click the printer program folder.
2. Double-click the printer Center to open the All-In-One Center.
3. From the "What is being scanned?" menu on the main screen, select a document type.
4. From the "How will the scanned image be used?" menu, choose To be viewed on monitor/web page.
5. From the "Send scanned image to" menu, choose an application.
6. Click Scan.
7. Retrieve the scanned image from the application, and then send it through e-mail as an attachment.
I hope this information has been helpful.
Sep 19, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
Turn on your all-in-one printer and computer. Check the connections between the two machines.
Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
Close the printer's document lid slowly so the document does not shift position.
Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
Push the scan button. You may have to do this on the printer itself or on your computer.
Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
Accept the scan and save. Return the original document to a safe location.
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
Apr 20, 2010 | HP Photosmart C7280 Laser Printer
How to scan from printer to computer
Hi friend,
follw the given instructions for scan the documents from printer to computer,
1-switch on your all-in-one printer and computer.
2-Check the connections between the two machines
3-open the peinter surface,Put the document which you want to scan and face-down on the glass. These are usually found on the left-hand edge of the scanning area.
4-Close the printer’s document lid slowly so the document does not shift position.
5-Select a scan resolution.
6-Push the scan button. You may have to do this on the printer itself or on your computer.
7-Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
8-Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you resize
9-Accept the scan and save. Return the original document to a safe location.
Thanks,
Dec 16, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
How do I scan something from my wireless printer to my computer
There are two options.
Option 1
Make sure your computer is on. Insert the document you want to scan. Click on the scan button on the printer. The document will automatically be scanned and saved in your computer in mydocument under mypicture->my scans folder.
Option 2
Insert the document which you want to scan in the scanner. From your computer invoke HP Solutions Center. There you will see options to scan the document.
Please note for both the options you must have installed all the softwares which came with your printer.
Nov 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
Aug 10, 2009 | HP Photosmart C5580 All-In-One InkJet...
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
229 people viewed this question
Seeker5211
Seeker5211
