2000 Nissan Quest Logo
Posted on Aug 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 nissan altima
Hello! I have a 2003 nissan altima. For about 3 weeks it had the "check engine" light on. For about 3 times when I started my car the engine started but then the engine went off inmediatelly. This morning I did the same thing and the engine went off again. Any help!!
Thanks.
  • Anonymous May 11, 2010
    Unfortunately there are literally hundreds of things it could be. Need to take it to a shop for diagnostics.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Sep 16, 2008
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
70324
Points
223
Most likely cam and or crank sensors. Have it scanned to be sure.
1helpful
How do you get the bolts loose from the alternator for a 2003 Nissan altima 3.5
Kathy, R&R info./instructions in links below. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2003 nissan altima 3 5l v6 alternator part 1
how to replace the alternator on 2003 nissan altima 3 5L alternatoe...
2003 nissan altima 3 5l v6 alternator install 1
2002 Altima Alternator How Do Replace the Alternator on My 2002
My nissan 2003 altima 2.5s cannot take gas
Could be low fuel pressure or a faulty throttle position sensor.
Have the fuel pressure checked and if the check engine light is on have the computer scanned for trouble codes.
1helpful
TCS OFF Slip
probably a wheel speed sensor has kicked the bucket, which is why the tcs light came on , have to check your ABS system to see if its functional.
My 2003 nissan altima is taking long to start.
If the check engine light is NOT on, it will be a mechanical problem like a clogged air filter, fuel filter or faulty spark plugs. If your check engine light IS on, it is a sensor like the O2 or MAF for example. Best to get it diagnosed if the check engine is on to specify with sensor is causing the problem.
2answers
I have a 2003 altima the temp gauge is running cold and the check engine light went on What can the problem be?
Just run it by auto zone and they will hook it up and read the code for you for free.
When i try to start my 2003 2.5 altima i have to
3 to 5 seconds is not really excessive. You might, however, want to try this...depress the gas petal to the floor then turn the ignition while slowly raising you foot off the accelerator. If this helps start the car the check engine light is probably indicating an oxegen sensor problem.
How many engine mounts on a 2003 nissan altima 4 cyl
I TOOK MY CAR TO GET AN OIL CHANGE AND WAS TOLD THAT MY CAR HAS 3 MOTOR MOUNTS. I HAVE A 2003 NISSAN ALTIMA ALSO
3helpful
3answers
2003 Nissan Altima 2.5S, Check Engine Light Problem.
this problem could be caused by the mass air flow censor, i had the same problem with my car. it is really pricey at the dealer so you might want to check elsewhere for this part. I found one at a scrap yard for 85% less that the dealer and i also got life time warranty, the dealer does not offer any warranty on this part.
Check Engine Light
Nita0605 you should have included a little more infomation. Does the car drive any different when the light is on? Most likely you have a trouble code P0325.........Knock sensor fault or O2 sensor problem. I wouldn't worry about it until the light stays on
My car stalls or I have some trouble starting it. It turns over but takes a couple of seconds to start and then, sometimes, it stalls again. 2003 Nissan Altima w/155,000 miles [email protected]
is the check engine light on?? you may need a crank ngle sensor. pretty common problem with altima. nissan actually has TSB out for replacement of sensors. good luck.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
