Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Water leaking I have a Galaxy side-by side refrigerator and water is leaking fall on to the floor. I see the tray underneath is full of water. What do I need to do?? Help!!
  • 4,889 Answers
I think this will help..
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on Aug 21, 2008
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
Leaking under left side. water lines ok. too close to ground to see where water is. hardwood kitchen floor is buckled. ice maker is putting out too much ice and falling out onto shelf. what do i need to...
It sounds like the water tray for the defrost mode is full, you need to check if the tray has moved or maybe the door rubber are not sealing and this will cause extra ice built-up, and will cause the leak.
Jun 02, 2011 | Refrigerators
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Water leaking from underneath right side of refrigerator. Shut off water line to ice maker and still slowly leaking. Where is this coming from?
check the defrost drain line and catch tray under the fridge. you may just have moved the hose out of the tray or the tray may be full.
or it could just be your water valve has a slow leak. try turning off the water farther back on the supply line.
Dec 12, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Water is leaking onto the floor from underneath the refrigerator.
There is a condensor tray located underneath. It catches water and then the water evporates. Sometimes the tube gets plugged and causes a mess. Check the tube and the condensation tray. You can access the tray by just taking off the grille under the door on the front of the refrigerator.
Nov 17, 2009 | Whirlpool EL7ATRRKS Refrigerator
Refrigerator leaking water on floor under it!
The leak is most likely coming from the defrost tray below the evaporator coils. A piece of ice or something is preventing the water from draining to the pan below your refrigerator. Unplug and remove the back panel inside the freezer. Any blockage from that tray will cause the water to pool out into the freezer or fresh food section. Thanks, Sea Breeze
Jun 18, 2009 | Maytag MSD2656G Side by Side Refrigerator
Ice maker making little ice/Leaking water on floor.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
Feb 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool Imperial Series UltraEase II side by side refrigerator is leaking from underneath the left side.
hi. thanks for the question .pull fridge away from the wall. remove back panel, clean all coils. look for leak. the tray is suppose to evaporate, from the heat from coils ,and compressor .so it has to evaporate .thanks the appliance doc
Aug 17, 2008 | Whirlpool GD2SHGX Refrigerator
Moffat fridge leaks, every couple days water on floor at front of fridgee
The reason why it leaks is because the pipe that discards the water underneath the refrigerator is clogged and must be cleaned. The water normally drains through this pipe into the bottom tray of the refrigerator where this water deposit is supposed to evaporate during normal conditions. When the pipe is clogged then the water does not fall into this tray. Therefore, turn off the refrigerator (power off/ previous taking-out of all food of course!) than go behind the fridge and locate this pipe (plastic hose / if you have difficulty locate at least the tray on the bottom and than locate this pipe / to locate it you can see the little hole on the back bottom of the freezer this is where the water is supposed to get out. Put water into the hole and you can see where it falls). Clean the pipe and the problem should be solved.
Jul 09, 2008 | Refrigerators
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
468 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
