Question about Mitsubishi WS-65819 TV
Timer light blinking
When I turn on TV the timer light is blinking and TV goes off. I tried to unplug TV and it still doesn't work.
  • Mitsubishi Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Timer light blinking and tv won't turn on
Not much info to go off of, and the video is a bit blurry. Try unplugging the tv for a minute or two, make sure to leave it unplugged to allow power to dissipate. Then try again. Otherwise I would suspect power supply problem.
Apr 10, 2013 | Televison & Video
The tv turns on and back off and the on timer light blinks on
Try to reset everything in the menu section to reset the timer for tv some how was activated and needs to be turned off.that might help!!
Mar 01, 2009 | JVC AV-27920 27" TV
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Stand by/timer light flashes red television will not turn on
I will need to know the model number of your set to help you as well as if the light blinks a certain number of times in between pauses. Please respond to this same post.
Jul 16, 2008 | Televison & Video
On timer light blinks on/off tv does not turn on jvc av-32d502
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
  • Very simple thing you can try to reset the TV is to unplug it from the wall and leave it unplugged for about 5 minutes or so.
  • Next, replug in the power for the TV and see if the timer mode has been cancelled out.
Regards,
Feb 16, 2008 | Televison & Video
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
Mitsubishi WS-65819 TV Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
