Question about Konica Minolta magicolor 2430 DL Laser Printer
Ink cartridge problem
My printer is giving me a message that all of the ink cartridges are not installed, however they are and they are fairly new. I tried cleaning it, disconnecting and connecting again so it can reboot but the problem persists. What can I do next.
  • jfkadlec Sep 10, 2008
    i have exactly the same problem.
I contacted Konica-Minolta. They had me use a pen to depress the toner rack switch on the right hand side so that i could rotate the toner cartridges. I removed and replaced each cartridge, then used the pencil eraser. Then I had to use the rubber eraser from a pencil to clean the three contacts on the right hand side of each toner cartridge. After doing this, the unit again immediately worked.
While I had been using a paper towel to clean all the excess toner and on all the contacts on each toner cartridge, that apparently isn't enough even though the contacts looked clean. Perhaps there is a film of toner which gets on the little three contact site on the right of the cartridge.
The technical person also said if this didn't solve the problem, that he would have me remove all the toner cartridges and clean the electrical switch which comes in contact with the three little contacts on the cartridges (Perhaps that is the chip reader referred to by the previous post).
This must be a fairly common problem with this unit. I suspect that it occurs because there is so much free toner inside. However, I will now keep a pencil with a rubber eraser handy to keep it going. I will also keep the solution shown immediately before this one since it seems reasonable as well.
Posted on Sep 17, 2008
    Champion:
  • 214 Answers
Firs of all, pleas use search, here are many problem like this, this is a common problem for MC 24xx/25XX series.
you have to remove pc drum, and all toners, find small black plastic switch on right side from toners push it down with screwdriver, then you can rotate the toner rack manually, remove all toners, under the toners in right side you will see a chip reader with 3 pins, first check that all pins are in same level, if ok, then use pressure air to clean it, also clean toner chips, then reinstall everything.
If no help, then replace chip reader.
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
HP6180 Printer. I keep getting an error message, Ink cartridge em
some cartridges are charged up ( have a chip fitted to them )
If the chip is not charged to tell the printer it,s full of ink. this will cause the problem.
have you tried. unplugging the printer from the mains. then powering it back up.
also try using the printers own software to add new cartridges et,c.
you could also try re-installing the printers drivers/software if you have it,s instalation disk.
Mike @ Compurepair.
Jun 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Inkjet cartridges
Hello hotstikss
The following are some error messages, if you are getting any of these, then you will have to investigate by reinstalling the cartridge or installing a new one.
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
If this does not sove the problem please let me know.
Thanks
Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help with Epson Stylus CX 6000
I NEEED DRIVER OF INSTALATION OF IMPRESORA STYLUS CX 6000 PLIS MI MAIL IS marsa78_eva@yahoo.com.mx
Jan 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cartridge
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Oct 02, 2007 | Canon PIXMA MP160 All-In-One Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
88 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
