Question about Amana AEW4530DDS Electric Single Oven
Old Amana - no manual; can't operate self clean feature
My Mom has an old Amana Electric oven with a self clean feature but we're not sure how it works. There is a "clean" setting on one of the dials and a door lock but nothing happens when we lock the door and turn the dial. Should we set the temp for 500 and then use the clean setting? It's an old stove and we no longer have the manual. Thanks!
  • jimshrum Nov 30, 2008
    Has clean marked on the oven temp dial and door locks but nothing happens.
  • 876 Answers
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Posted on Aug 21, 2008
SOURCE:
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have Maytag ECWE550 How do I operate the self cleaning (never did it) or can I get a manual online?
When you use self clean the 900 degree temperature damages the electronics. I do not advise using that feature. Get some oven cleaner and do it the old fashioned way. My opinion.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 25, 2010 | Maytag CWE5800A Electric Double Oven
How do you operate the self cleaning option on a GE Talisman Royale Stove that's quite old
Before you try to run the self clean feature read this tip...
Mnay problems are cuased by the high heat of the self cleaning...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 12, 2010 | Frigidaire GLEB27S7A Electric Single Oven
No manual. How to set self cleaning electric oven that is approx. 20 yrs old.
If you can give the make and model of your oven a manual could probably be found.
However before you consider running the self clean feature be sure to read this...
Heatman101
Mar 10, 2010 | Stoves Ovens
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
Feb 20, 2010 | Ovens
I inherited an older Amana Gas oven that is self
Here is an older manual with instructions on self clean and everything else. Hope it helps!
http://shop.amana.com/assets/pdfs/literature/30946503.PDF
Jan 29, 2010 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have an electric Maytag stove/oven but don't know how to use the self cleaning feature. What do I do?
Dear cooper1914,
There are two types of Ovens that clean themselves.
1) A Self-Cleaning Oven which usually gets locked 1st then set on Self-Clean.
2) A Continuous-Cleaning Oven which is constantly cleaning
Some people prefer the old fashion clean by hand with degreasers but I prefer Self-Clean or Continuous-Clean as there is no need for harsh potent cleaners!
If you have a Self-Cleaning or Continuous-Clean Oven Do Not Clean With Cleaners as it will ruin the flavor of your oven!
Click on the following link for more info @ http://www.essortment.com/all/cleanoven_rbad.htm
Maytag Customer Support Manuals @ http://www.maytag.com/support/manuals_literature.jsp
jackiaria
Tuesday 02-24-2009 11:13am EST (USA)
Feb 24, 2009 | Maytag CWG3600A Gas Single Oven
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Amana AEW4530DDS Electric Single Oven Logo
538 people viewed this question
Top Amana Ovens Experts
Steve Allison
Steve Allison
Ismael Rodriguez...
Joseph Hoffmann
Are you an Amana Oven Expert? Answer questions, earn points and help others
