Question about Singer Sewing Machines
How many Watts does my machine have?
I recently returned to the UK from Canada and would now like to use my Singer 9805 sewing machine which I bought in Canada. To do this I need to buy a "step down transformer" and I have been asked how many watts my machine has. I can't find anything in the instruction manual I have or on the actual machine - can anyone help me at all ?
Thanks
Noella
  • 706 Answers
Watts is Current ( listed in Amps and normally shown on a tag of some sort on your machine ) times Voltage ( 120Vac) so if you had
For example.. if it listed 10A as in 10 amps @ 120 V then you would have 10 x 120 or 1200 watts.. This should get you in the ballpark.. If you can provide the exact model number of your machine.. I couold get the specs on it and give you a better answer.. Hope that helps...
Posted on Aug 21, 2008
  • Anonymous Aug 26, 2008
    U.S. sewing machines operate on 110-120 volts, 60 cycles. When taken abroad they require an Isolation-Type, Step-Down Transformer rated for 240-250 volts down to 110-120 volts and should be rated no less than 150 watts. This transformer should be purchased in the destination country so you will be sure it complies with regulatory requirements of that country and will have the proper plug for connecting to the wall outlet. This transformer should be fitted with the U.S. type of receptacle to accept our standard flat blade plug. By doing this, no changes whatsoever are required to the sewing machine electrics, and when brought back to the U.S. it can be used without any conversion.
    Sewing machines brought into the U.S. from abroad are usually rated for operation on 240-250 volts. An Isolation-Type Step-Up Transformer rated for 110-120 volts up to 240-250 volts is required. This transformer should be rated no less than 150 watts and can be purchased at any reputable electrical supply retailer..
SOURCE:
Singer 306K original Manual states needle is 206 x 13 dont seem to be able to find any, what can i use that doesnt drop stitches?
Help with Singer 306K - Sewing Discussion at Stitcher's Guild ...
artisanssquare.com > ... > Sewing Machines
Nov 22, 2013 - 33 posts - ‎8 authors
Unless,the original bobbin case has been modified,or someone bought a newer ... In Ed's blog here are pictures of a 206x13 needle vs a regular 15x1 needle and ... Here is a free Singer 306K automatic sewing machine pdf manual,with ..... I was upset and so I didn't get any more details over the phone. Author Topic: Is there such a machine as
Jul 6, 2012
Singer 319 find
May 13, 2009
More results from artisanssquare.com
Missing: states
Singer 320K2, Singer 306K Bobbin Case Conversion for ...
andrewcaddle.com/.../singer-320k2-singer-306k-bobbin-case-conversion...
Sep 13, 2014 - I recently had the good fortune to pick up a Singer 320K2 sewing machine. ... as well as Singer's zig zag model 206 utilise a needle design (206X13) which ... The 206×13 needles are becoming rare, with only two sizes and only one ....Neither can I state, beyond any doubt, that this modification won't cause ...
Jan 11, 2016 | Singer Sewing Machines
Looking for a sewing dealer
It appears that there are quite a few service centers in Ontario--far more than I can list here, but if you go to the Singer site at http://www.singerco.com/support/warranty-centers/search, and select Ontario, Canada, you'll see a list.
Sep 11, 2014 | Singer Sewing Machines
How to fix a seized hand wheel on a singer 9805 sewing machine?
Hi Willow,
Most often a seized wheel is because there is a lot of thread jammed at the needle. I suggest you first check the needle and the bobbin beneath the needle and remove all thread and lint build up. Hopefully this will get your machine sewing again. If not provide more details of your problem so I can help further.
May 12, 2014 | Sewing Machines
SINGER 132K6 sewing backwards only
Yes the wiring is backwards so the motor runs the opposite way.
May 18, 2013 | Sewing Machines
Manual for singer 9805C
Go to the singer website for a free manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9805) DO NOT PUT THE C
IN THE BOX WITH THE NUMBERS
& click search
Jul 27, 2012 | Singer Sewing Machines
I have a brother sewing machine working on 220 v . i curently live in Dubai U.A.E and planning to move to canada, can this machine work there? i know they have 110v there. can i convert mine to a 110 v....
I would suggest finding a travel adapter for the voltage. I moved from the US to the UK for a while and used an electric travel adapter for my singer machine for the time I lived there. It functioned very, very well.
I hope you enjoy Canada. It has some beautiful country there. I know I, personally, welcome you to the Western Hemisphere, Samira!
Beth
Jun 08, 2011 | Sewing Machines
Sewing Machines Logo
756 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
