Question about Miele Novotronic Premier 500 Front Load Washer
Leaking Water is leaking from the bottom where the cleanout is. What could be the problem and how can I fix this?
  • Frazzles Aug 28, 2008
    Mine's a WT2670 - leaking from the bottom front panel near the floor
  • 128 Answers
The panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Cleanout any debris and reassemble. If the leak continues - opem the front cover and examine the hose connections in the filter / drain pump area - the oring on the drain pump is the most likely culprit.
Posted on Nov 27, 2008
  • 4,889 Answers
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Aug 21, 2008
2 Suggested Answers
  • 13 Answers
SOURCE: Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Posted on Jan 07, 2008
Water in freezer bottom
My tool of choice is a chopstick but something of similar diameter that will not damage the drain line can be used.
Oct 01, 2014 | KitchenAid KFIS25XVBL Bottom Freezer...
Honda gcv 160 engine have to have the choke half way closed to run
Hi. Remove the float bowl nut and cleanout the hole the float bowl nut screws into. Also clan out the side holes in the float bowl nut itself. There is debris in the bottom of the float bowl tht is restricting fuel flow. Pretty simple fix. Just make sure that you have the bowl gasket aligned when you re-install the float bowl. Otherwise it will leak fuel.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Garden
Spin is not working in my lg washing machine
See if there is still some water left in the tub, which would indicate a drain issue. A front load WM will not go into high speed spin if it detects excess water in the tub. If there is water, there may be a small door at the bottom of the front that leads to a drain pump cleanout. You would not believe the things I have found that can block a drain pump. Have a wet vac and towels ready, because all the water remaining in the WM will have to be sucked out as you open the cleanout. If your problem is not excess water, it could be a control issue or a problem with the stator motor at the rear of the tub. You would probably need a service tech to check it out then.
May 31, 2010 | LG WD-16115FD Front Load Washer
I have an Axxis+ washer/dryer. The washer is giving me an F:34 error, any ideas?
you can try this I had one of these the other day. On the bottom front of the washer you will find a round access cover, rotate it to the right to remove it, inside you will find a green cord to manually unluck the door, pull it down. Door should now be unlocked. Chances are the door won't unluck because the wash water is not draining from the washer due to a clogged drain pump. Right behind that round access cover is the water pump. Before you open the pump cleanout, soak up all the remaining water inside the wash basket of the machine, or use a wet dry vacuum to vacuum up the water. Have a shallow pan and lots of bath towels to catch the water when you open up the drain pump cleanout. Check the drain pump cleanout for lint, small socks, coins and whatever gets left in pockets of clothes.http://servicetechhelp.com/discus/messages/2801/65423.html?1241057606
May 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Frontloading duet HT retaining water in the tub
THE ONLY THING BETWEEN THE TUB AND THE DRAIN IS A
PUMP/MOTOR AND CONNECTING HOSES. THERE IS ALSO A CLEANOUT BEHIND THE FRONT LOWER PANEL. REMOVE THE PANEL BY REMOVING THE THREE SCREWS ALONG THE BOTTOM EDGE. PULL DOWN ON THE PANEL TO REMOVE IT. A LARGE CAP ON THE FRONT OF THE CLEANOUT CAN BE UNSCREWED TO REMOVE A FILTER.
CLEAN IT OUT AND INSPECT THE ENTRANCE INTO THE PUMP HOUSING. MAKE SURE IT IS CLEAR. REASSEMBLE AND CHECK OPERATIONS OF THE WASHER.
Aug 01, 2008 | Whirlpool Washing Machines
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Miele Novotronic Premier 500 Front Load Washer Logo
901 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
