Remove the batteries and hold down one or more of the buttons for several minutes to drain the microprocessor inside the remote to reset it. Reinstall batteries and try the remote again.
You better open your remote and clean circuit board inside.Dirt and dust can caused to malfunction of almost all button.When open already brush it with toothbrush with alcohol and dry it with the use of a hair dryer.
The issue you're experiencing with your Samsung UN50EH5300FXZA TV cycling on and off when you press the menu or source keys could be due to a hardware malfunction in either the main board or the power board. Here are some steps you can try to resolve the issue:
Power reset: Unplug the TV from the power source, wait for a minute, and then plug it back in.
Check the cables: Make sure all cables are securely connected to the TV and the wall outlet.
Check for firmware updates: Check if there are any firmware updates available for your TV and install them if necessary.
Factory reset: Perform a factory reset on the TV to erase all settings and return it to its original state.
Contact Samsung support: If the issue persists after trying these steps, contact Samsung support for further assistance. They may be able to diagnose and resolve the issue.
Murphy's law says that the tv only does what it is told. No flashes on it's own? Check the remote battery's first easiest. Then open the remote to see if these is dirt or dust in the keypad. If some liquid got in there clean with solvent on a rag. Don't put the solvent on anything else. Wipe off the sending unit on the front of the remote with damp rag. If this does nothing then blame the tv or get another remote to try out.
On blu ray remote control hold down TV Power+01 at the
same time. If the TV turns off the controller is programmed. If not, try TV Power+02,
+03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Turn the TV on, on the remote, press and hold SET-UP until the light blinks twice,then release, enter 9-9-1, the TV key will blink twice,aim the remote at the TV and press and hold POWER and TV slowly alternating from one to the other, stop when the TV turns off, press SET-UP the TV key will blink twice....hope this was helpful...
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
my retoe control will only work the volume on my tv
