Question about Acer Aspire 5500 5570-2609 Laptop
Aspire 5003WLMI No Power
Hi, my LT has suddenly stopped working with no sign of any power at all. I have tried a known good battery and AC adaptor but still no change. I have tried the AC adapter without the battery and no joy. Anu suggestions?
  • neil692 Aug 26, 2008
    Hiya,
    What sort of hardware issue can it be? I am fairly savy and am able to replace any suspect parts myself its just that I dont know where to start!
    Cheers
    Neil
  • 128 Answers
You have a hardware problem which would require opening your laptop. i suggest you bring it to a computer technician who can do the repair for you to avoid further damage.
Posted on Oct 15, 2008
Compaq Presario V3000 SUDDENLY DEAD
Remove the battery and try on the AC adaptor only. if it still doesn't work try a new adaptor.
Apr 06, 2012 | HP Compaq for Presario V3000 Motherboard
Acer laptop will not boot up
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Acer Aspire 5610-4648 Notebook
Hello acer Aspire model number 5052 AWXMi wont power up, there is no signs of life no flicker of leds and i have tried removing and replacing cmos battery, i have also held power button for 20 secs but...
Hi
Take the battery out and put the unit on the AC charger and try to start. If it starts your battery is bad. If it does not start then an IC has come away from the mother board. A reputable service tech will have a float device to reheat *********** board and resolder all the IC's
Aug 12, 2010 | Acer Aspire 5050 5430 Laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
HP Pavillion 6000 battery issues
Hi Steve, If you haven't gotten any batteries to work properly at all and the problems are different each time, I would say the motherboard is shorting out the batteries and causing weird problems. One last thing to try if possible..
Try a known good working battery, if that battery doesn't work then its verified that the motherboard is bad. If the known good working battery works in that laptop then you got a bad batch and it will be a battery problem.
Since your laptop turns on with the ac adaptor means that the ac adaptor is good.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Dell Inspiron B130 Battery Problem
Sounds like the cells in the battery went bad. Try to turn on your laptop with just the ac adaptor hooked up and your battery out off the laptop to make sure that your ac adaptor is working properly. If you can boot up into windows with just the ac adaptor hooked up then you know your ac adaptor is good.
If you get that far then try a different battery and see if the laptop charges with another known good battery. If it does then you know your original battery is bad. If it doesn't charge your different known good battery then you know the motherboard is bad. Hope this helps.
Ben
May 26, 2009 | Electronic Arts The Lord of the Rings: The...
Hp pavilion 4000, will not recharge battery, i have a new battery, my electiricl cord is good, will not power with electrical,
If the battery is a known good one and the ac adaptor is a known good one that you have used before, then it has to be the motherboard that is faulty.
Make sure your using a good power outlet to hook the ac adaptor to just to be sure.
May 10, 2009 | Dell Inspiron 6000 Notebook
Toshiba Satellite 1405 - Power problem
Hi Don
Although symptom is showing that AC Adaptor is not working as its not providing power to the unit. I will suggest you to perform some basic troubleshooting steps. Check if outlet is working if not check with known working outlet. If you have a multimeter you can the output of the AC adaptor.
Also you can perform full power cycle and component discharge. Take the battery out and disconnect the AC adaptor press the power button and hold about 7 seconds. After that put the AC adaptor in and test again.
If issue persist take to nearest Service center check with known working AC adaptor. After that I believe you will figure out the best solution.
Good Luck
Jan 21, 2008 | Toshiba Satellite 1405-S151 Notebook
Wireless problem
Are u staying at the same place when u plug and unplug the AC power outlet?
Jun 03, 2007 | Acer Aspire 5003WLMi Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
