Question about Dell 924 All-in-One InkJet Printer
Printer keeps trying to print even after cancelation
I ran out of ink and the printer would not print . After I replaced the cartridge the printer prints a item over and over that I canceled several days ago . It keeps trying to print even after I cancel the printing Thanks Ron Patrick
email rpatrick64@bellsouth.net
  • 1 more comment
  • rpatrick64 Aug 21, 2008
    Printer keeps running old print reguest and blank sheets . Will not stop running even when printing is canceled . All this occurred after new Dell ink cartridge was in stalled .
  • rpatrick64 Aug 22, 2008
    When I click to print the printer diagram shows up on the screen . The blue line that runs horizonal to show the percentage of printing that has run takes about a second to run 100% . The printing diagram then shuts off without printing anything .
    All of your representatives response did not show up on email . Part of a sentence was gone.
  • 197 Answers
The best way to solve this problem is to uninstall all drivers and reinstall all drives for the printer that way you will have clean setup and it will not give you any more problems and not print on its own.
thanks
hope this works for you
Posted on Aug 22, 2008
    Master:
  • 521 Answers
Disable the printer n uninstall the drivers.reinstall the drivers n turn it online.all the old memory will be out of it.and the printer will run properly .u will be back to work soon.thanks pls do rate the solution.
  • 1,879 Answers
Disconnect the printer from the computer then reboot everything.
delete all print queues (while printer still disconnected).
delete the printer icon
re-connect the printer & the computer will auto detect it.
    Genius:
  • 1,268 Answers
Before uninstalling or reinstalling drivers, try first to Disable the printer.
Go to Control Panel > Printers and Faxes
Right-click your default pinter > Disable. Turn off printer for about 2 minutes.
Enable now the printer icon on printers and faxes (right-click then Enable). Turn on Printer now and try to print.
Or you can simply switch the Ports that it's using temporarily on the pinter settings
Again on Printers and Faxes, Right-Click your default printer icon > Properties
Go to Ports tab. You can see there check boxes where in the USB is checked. Check the other ports like LPT1 or File and click Apply. Now put check to the USB again and hit OK. Then try to print.
Hope that helps!
Posted on Aug 21, 2008
    Master:
  • 623 Answers
Go to device manager and scan for hardware changes
  • 1,029 Answers
Off and try restarting the printer.go to the menu press reset
  • Starnley Johnwells
    Starnley Johnwells Aug 22, 2008
    i think the problem should be from the printer appllication try re installing the printer and check the settin
    Genius:
  • 2,035 Answers
Please uninstall and reinstall the drivers then try to print:::
  • Dell Master
  • 6,487 Answers
You're saying that you already cancel all the pending print jobs? if yes can you please double check and make sure that all print jobs are already cancel, then just restart your computer and printer and check if its working fine now..
Hope that helps........
  • Mark Gil
    Mark Gil Aug 21, 2008
    Did you already restart the printer and computer? if you already restart the printer and computer, Try to remove again the cartridge ad put them back in the try if you still have the problem....
  • Dell Master
  • 13,433 Answers
Goto your printers and faxes, uninstall your printer from there, restart the computer and the printer. it should stop printing old things, and you need to install the printer again, but it should do that automatically as you have the drivers and software on your computer, so just restart and should work fine.
  • 928 Answers
Its possible that its a buffer on the printer depending on the type of printer that you have. Turn off your printer for about 5 mins then cancel all prints then restart your computer before turning on the printer.
  • Thomas Lim
    Thomas Lim Aug 21, 2008
    Try removing the ink cartridges then turn off the printer. Turn on the printer and reinstall the ink cartridges. See if that fixes it. Although there would be no logical reason why it would fix it but sometimes it is the case with problems like this.
  • Dell Master
  • 19,396 Answers
Try reinstalling printer drivers, from disk or from Dell website.
  • Ginko
    Ginko Aug 21, 2008
    Do the following:
    • Unplug printer USB from computer.
    • Uninstall printer from 'installed printers' in Windows Control Panel.
    • Insert printer disk or install drivers after download from Dell website here :
      Drivers and Downloads
    • Run printer drivers setup wizard and follow instructions.
    • Connect printer when asked by setup wizard.
    This should fix the problem, unless printer is faulty, but it does not look faulty from description.
How to resume printing. Showing 'E'.
search google.com for error codes with make and or model
Mar 07, 2015 | Office Equipment & Supplies
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
kriegersugar@yahoo.com
Mar 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Won't print; ink light blinking;
there is a queued job that was still pending to be printed, you have to cancell all documents uner your spooled files pls
unless otherewise you cancel this files you cannot print at all, it hangs somewhere, thats why yo ahve this prob
Dec 07, 2008 | HP DeskJet 6122 InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Dell 924 All-in-One InkJet Printer Logo
61 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
