Sony KE 32TS2E Horizontal black line - Televison & Video
  • 1 more comment
  • salahdread Nov 21, 2008
    It's Horizontal and vertical black lines( one horizontal black line cross one black vertical line)
  • HerotsLegacy Jan 05, 2009
    I've "inherited" one of these from friends next door, it has three horizontal black lines, equally spaced about 3mm apart, and 10cm from the top of the screen. I'm guessing that the panel is addressed as a matrx, with row and column drivers and this might indicate a bad connection on the row drives, so I tried re-seating the massive multi-pin connectors, and adding a little "Tweek" electronic lubricant, no luck. The fact that the three lines are equally spaced also suggests a digital decoder problem, but the boards are a mass of vapour-soldered pin grid arrays, so I'm not going in there.
  • Anonymous Jan 05, 2009
    I have same plasma TV that is 3 years old and there is one such vertical black/green link.
    There is not way to fix it yourself and the best way to deal with is contact Sony for free repair, if they don't do it join a class action law suite.
    Good luck.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Posted on Aug 09, 2006
ginko
  • 19396 Answers
SOURCE: I have a Sony tv
Hi.
What users call solarization is a false contour effect caused either by video processing problems (often due to overheating), or by a defective plasma panel.
I have never seen a problem of this kind being caused by defective PSU.
There is a lot of false or wrong info on this topic published on the Internet (the term solarisation has been invented by users, this phoenomenon is not the same as digital image solarization in photography).
I wonder what eleimination process you used, and I wonder to what URL you are referring to.
If the problem is false contour, red faces and lack of contrast, it can be a problem related to main controller board, rather than PSU.
In the general confusion that dominates threads talking about "solarization", often problems due to incorrect picture settings, where no fault is present are often referring to solariaztion (eg. those rubbish pages titled "How to discover if TV has solarization before buying a TV".
If problem is very evident and does not go away changing picture settings, then problem is either main controller, G2 board (ausiliary graphic controller) or plasma panel. Problem is often associated to overheating.
If you are sure that the TV is faulty, as first line of action rather than attempting repair, I suggest calling Sony. You have three years factory warranty, and if really there is a factory defect, Sony will fix it even out of warranty.
Regarding the PSU, this is tested, reading the AC input, checking power cord for continuity, testing zener at AC input, testing individually resistors at outputs (ensure continuity), jumping activation lines and reading volts outs on different values, starting from 3.3V. When the PSU is defective, TV wont start, or will turn off by itself. Your problem is not PSU.
Below a service manual with full schematics, adjustment and repair procedure. As first thing call Sony.
To download part one, please, click here.
To download the part 2, please, click here.
Regards.
Ginko
Posted on Oct 12, 2010
  • 11800 Answers
The only way to find out is to test it: if you don't have a great experience in electronics the only way you can do it is to take it out of the tv and check every single component. Start with the transistors, follow with the rectifiers, then check the stabilizers and finally the transformers.
Posted on Oct 21, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Sony Bravia Kdl-32nx503 thin black horizontal line on TV screen
T'Con board fault. Contact the authorized service centre for Sony. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Sony Televison & Video
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony tv KE-32TS2E The problem with this tv is solarisation I have established that the problem is in the power supply board ( by ellimination) How can I find out which component in the power...
Oct 21, 2010 | Sony Televison & Video
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly...
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Aug 21, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Sony ke-p42m1
dunguard, How long have you had this for, zazwpx
Jun 04, 2007 | Sony KE-P42M1 42 in. Plasma Television
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Televison & Video Logo
356 people viewed this question
Top Televison & Video Experts
