Question about Saeco Vienna De Luxe Espresso Machine
Resevoir leaking on Saeco Trevi(like Vienna)
I have ordered the part by number on the SaecoUSA site.Thank You. Can I assume the piece I pryed up to see the gasket can be completely removed in that manner? No set screws, etc in order to replace gasket? Thanks again, You were most helpful, Jim
  • 515 Answers
There are no screw to be removed, you have to take off the plastic ring in the water inlet. Take a screw driver and set it between the chassis and the water inlet.
Hope this will help you.
/Mirran
Posted on Aug 21, 2008
SOURCE:
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Jan 21, 2013 | Saeco Vienna Espresso Machine
Saeco Incanto "grinder blocked"
provide in detail about your problem ..........
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
I cant take out the brew group of my saeco vienna espresso machine
have to make sure the group is in part. turn machine off and on should hear the motor go. if the group is stuck take the small screw out of group and will release piece thats on the injector. MUst hold the lever on the front of the group to relase the lock then gently pry it out .
Dec 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Trevi leaks from "inside"
What can have happened is that through an overflow of used coffee the hole in the back is stuffed with the ground used coffee. The way to solve this is getting out the brewing group and rinse the hole with water after removing the cloggin coffee residu. You can find this hole just beneath the outgoing axle.
Mar 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Contact Saeco USA and see where they have a local service for Saeco.
Saeco USA Inc.
7905 Cochran Road Suite 100
Glenwillow, OH 44139
Tel. 440-528-2000
Fax 440-542-9173
E-mail: [email protected]
Visit the Web: www.saeco-usa.com
/Mirran
Aug 17, 2008 | Saeco Vienna De Luxe Espresso Machine
you have to replace the gasket in your water inlet, if you look where the inlet is you will see there are a little gap between the chassis and the inlet.
Take a screwdriver and bend up the plastic, you will now see the gasket.
The gasket have spare part number: 145842900
/Mirran
Aug 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
SAECO TREVI NO HOT WATER
It would be cheaper to check the thermostat and heating element first and the wiring continuity, although I am not sure if you can find the replacement parts. If you can't, then it looks like you have no choice but to replace the entire assembly.
May 19, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
85 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
