Question about Tektronix Office Equipment & Supplies
I have a Tektronix Phaser 540 with an error code 32 when I powered it up. Can you tell me what this means?
  • lindagutz Aug 21, 2008
    I replace the imaging unit and that fixed the error. Thank you,
  • Tektronix Master
  • 1,879 Answers
This is from the 560 manual hope the codes are the same. The 560 manual states : Accumulator belt cleaning blade movement error.
1. inspect the cleaning blade{located on the imaging unit,along the bottom of the green OPC belt. Is it flipped up? If you cannot flip it down, replace the imaging unit.
2. Inspect the wiring harness leading from the cleaning board to CN18 of the engine control board.
3. Replace the cleaning board.
4. Replace the engine control board.
If the above info does not match your model call :
(800) 833-9200 Press 3
(503) 627-2400
Posted on Aug 21, 2008
SOURCE:
Tektronix 540 error 32
Error 32 is most often caused by the cleaning blade clutch grease gumming up. Clean it completely with isopropyl alcohol and a lint free cloth and cotton buds. Re lubricate it with high temperature auto synthetic grease - make sure it has no mineral content.
Oct 07, 2009 | Tektronix Refurbished Phaser 560 Color...
Tektronix Phaser 840 Model Z840 shows error 08 001 44 215264
Check for broken Maintenance Drawer Guides, or the Printhead Cap/Wipe/Purge assembly is defective. (If it is for a Phaser 840)
Dec 05, 2008 | Xerox Phaser 8400 Laser Printer
Printer error code 61 on a tektronix phaser 550
Hello Sancorp,
In order to provide you a better solution I request you to provide me the opearating system you are using and also the make of the computer.
Thank you.
Oct 26, 2008 | Tektronix Office Equipment & Supplies
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
PHASER 8500DN ERROR CODE: 09,038,46.8515
That is a black ink stick count failure.
It is not seeing the black ink stick.
See if a stick is broken or not in place. One may be twisted or just jammed.
Outside chance you would need an ink loader because the sensor is not detecting the ink
Check the black sticks see if you can clear it by moving them around or sliding them up and out and reloading.
Mar 08, 2008 | Xerox Phaser 8500/DN Printer
Phaser 850
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: [email protected]
Feb 08, 2008 | Tektronix Phaser 860DP Thermal Printer
Code 09,038.46:4776 whats wrong
that code indicates most likely you have an ink stick in crooked, a broken ink stick in or added pieces of an ink stick.
That code is showing that you most likely have an ink stick loaded incorrectly or it broke.
Nov 28, 2007 | Xerox Phaser 8500/DN Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Oct 08, 2007 | Tektronix Phaser 860DP Thermal Printer
Open Questions:
227 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
Vincent G
Vincent G
STEVE
Vuk B
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
