LCD TV Is it possible to connect an existing aerial co-axial cable and plug to any hd ready lcd tv?
  • 24 Answers
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Posted on Aug 21, 2008
SOURCE:
How to connect antenna to klv 40u100m
Correct. You have to connect the antenna to another box and then take the output of that box to the TV. An old VCR is ideal as this box.
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Sony Led Lcd tv and the picture keeps breaking up and I can see pixels and the voice breaks up too. Could it be the aerial cable. We had a new HD aerial installed on the roof.
More than likely. There is no such thing as an HD aerial, there is no difference.
It is a sales description. Like Digital Ready and all that stuff.
The HD is your receiver, not the aerial.
Jan 29, 2011 | Televison & Video
It pause temporarily at times during regular tv programming. What can the problem be?
I'm not quite sure what you mean by "pause", but if you mean the picture freezes or pixellates and the sound cuts outs then it's caused by a bad signal - know as "Digital Cliff Edge" - see attached image.
If you are using an aerial, check all your cables are connected properly and that your aerial is securely mounted, pointing in the right direction and none of the elements have become detached - particularly the dipole where the co-axial cable attaches.
If you are using a dish, again check all your cables are connected properly and that your dish is securely mounted. If the bolts are loose and you can move the dish by hand, then it's possible that your dish has moved from the correct alignment. You will ideally need a signal meter to correct this although it can be done by trial and error.
You should also note that dishes are susceptible to signal-loss during bad weather, particularly strong wind, heavy rain and snow. If you are only losing picture in bad weather, there isn't much you can do apart from making sure the dish is rigidly fixed.
If your aerial/dish is OK, try replacing your fly-leads (the short section from the wall socket to the TV) and/or the cable from the aerial/dish to your TV.
Hope this helps.
BElectric
Nov 05, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Cant retune to pick up dvb samsung le 26r74bd
Hi return the TV with out the aerial connected and wait until it finishes then plug the aerial back in and try again. Let me know how you get on.
Apr 22, 2010 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Howto connect a ficture/film from computer to tv
there is a wireless signal sender that you can connet to the tv from your computer and it will send the signal so you can use your home tv as a computer monitor from any room in the house. search the internet
Sep 09, 2009 | Televison & Video
Insignia LCD 42. No Signal
there are a number of things you can try
1) dont use and indoor aerial use the one on the roof
2) try chanaging the aerial cable
3) get a signal boster
4) try tuneing manualy
if does not work then the tv has a fault
Jun 19, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Poor reception on only two lcd tv channels
if its only on 2 channels, its not your tv. its broadcasting that way through the cable. if it was the tv, it would be on all your channels, on all the inputs
Mar 15, 2009 | Samsung LNS2652DX 26 in. HD-Ready LCD...
Pay tv cable
you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Mar 06, 2008 | Televison & Video
Weak signal
Try a signal booster
http://cgi.ebay.co.uk/TV-DIGITAL-FREEVIEW-SIGNAL-AERIAL-AMPLIFIER-BOOSTER_W0QQitemZ160223681947QQihZ006QQcategoryZ73383QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Mar 05, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
Ekse
