Question about OKI C5150n Led Printer
Okidata C5150 Servicing
I would like to service my Okidata C 5150. What is involve in doing this?
  • Anonymous Mar 17, 2014
    Okidata C5150 error 400 paper size
I just changed all my color cartridges but the color printing does not show the right color. Is there a way to calibrate the colors or check how each cartridge is working or not?
Posted on Sep 06, 2008
In need to know if my C5150 will work with a Windows 10 laptop?
Which C5150 do you mean?
If you have an HP Photosmart C5150 all-in-one, it will work with Windows 10. HP has the full-featured (drivers and the HP Photosmart Suite) and diagnostic software here: https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-c5100-all-in-one-printer-series/1153538/model/1153544 .
If you have an OkiData C5150, the available drivers for that support Windows 7 (32 or 64 bit) and older versions of Windows. The compatibility tricks that let older drivers work may not work with Windows 10. (Microsoft now requires signed drivers and the available x64 driver from Oki may not meet the requirements.)
I hope this helps.
Aug 14, 2017 | Computers & Internet
Why can't I use a toner and drum set from an OKI c5250 in an OKI c5200
While the drum units may appear the same, chances are Okidata puts a different chip on it that makes in incompatible. The C5200 will use drums from a C5150. The C5250 appears to use different supplies.
Sep 14, 2014 | OKI C5250n Printer
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
C5150 ALL IN ONE Printer
first of all it require servicing like cleaning of steel rod inside in the printer on which print heads move ,that you can do with lubricant oil and second thing you need to change the cartridges because they may be already dry because you have limited use. In short if you can do this entire thing well otherwise I advised you to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Feb 03, 2012 | HP PhotoSmart C5150 All-In-One InkJet...
Have a inkjet 5150 when trying to print carriage jams makes grinding noise but does not load paper
It is requiring servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Thanks.
Have a good day
Dec 24, 2010 | HP DeskJet 5150 InkJet Printer
Code 356 Belt replacement needed for Oki C5150
By removing all the cartridges you'll find the belt. Replacing is very simple. Lift it out and put in the new one.
Jul 24, 2010 | OKI C5100 Laser Printer
My Oki C5150 is not recognized by Snow Leopard.
I had same issue...I called OKI 800 number and they walked me thru it - no problems at all now.
Sep 23, 2009 | Office Equipment & Supplies
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
OKI C5150n Led Printer Logo
419 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
