Question about RIM BlackBerry Pearl 8100
Blackberry Curve is resetting itself for no reason
I have had my blackberry curve for about 2 years now and it all of a sudden starts resetting itself. Sometimes when i take out the battery and put it back in it stays on for awhile then it will just start resetting itself again and won't even come to the main screen. HELP. This is my second blackberry because the first one the screen went white on me and they warrantied it, but this one is out of warranty.
  • 1 more comment
  • Anonymous Sep 03, 2008
    resets while calling.....
  • pdiez7 Sep 09, 2008
    i just removed the battery last night right after that the phone is not working it show a message " jum error 102 reset" what i should do.
    Thanks
  • Evlbarbie11 Sep 22, 2008
    I have the same problem. My curve kept resetting itself but would turn on after a few moments. Now it wont turn on, the screen just goes white and it says there is a JUM error. Help!
  • 21 Answers
Ok, you have a couple of things you can try...first, Try to wipe your handheld and see if that will solve the issue. Before doing this you will need to back all of your info up to the computer. If that doesnt take care of it then...second... Download the new software ( redownload the software if it is already current) to the phone through the blackberry desktop manager.
Posted on Sep 24, 2008
SOURCE:
How can i fix my blackberry 9320 for keeping on starting itself
take the battery out for 20 seconds then turn it on, if this doesn't work you should do a hard reset
Mar 15, 2014 | RIM Blackberry Curve 9320 Smartphone -...
The screen whites out n only way to get it back is take battery out n let it start back up
Hi there
Whenever your screen goes white again just hit the ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
Try freeing up some space on your blackberry by deleting some unecessary files and do not run too many applications at once.
Oct 11, 2010 | RIM BlackBerry Curve 8310 Smartphone
How do i reset my app error 523 on my t-mobile blackberry curve it keeps saying reset every time you turn on
Options, Security, General Settings then hit the menu key and select wipe handheld.
If that doesn't work try this
Also you can do a hard reset:
1. Take out the battery.
2. Wait 5 seconds.
3. Press and hold the power button.
4. Put the battery back into place while still holding the power button.
Apr 15, 2010 | AT&T Blackberry Curve 8300 Smartphone
2 year old BB Curve 8330 over heats
its the battery ........the more you charge them the less they hold a charge ...if yo look at your battery it is probably swollen from charging
Mar 09, 2010 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve 8330 won't turn back on
Pull the battery out and put back in. Then hit the reset button on back panel.
Sep 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
Am using blackberry curve, only track ball is not working why ?
There is no setting to resolve this problem. The only thing that you may try is a soft reset. Remove the battery from the back of the phone for about 10 minutes and then put it back in.
If the soft reset would not do any help, return the BlackBerry and ask for a replacement.
Have a great day!
Aug 16, 2009 | RIM Blackberry Curve 8300
Blackberry just randomly shuts off
check your battery terminal. I had this same problem right out of the box. it would only stay on for 15secs shut down and continue to cycle. turns out one of the 4 prongs wasnt connecting right with the battery. I could clearly see one was shorter than the others.
The phone would only work if connected to the computer.
Are you within your 30days? or 1yr manfacture warranty? or 90 days if it refurb (ATT)(anyway)
Jul 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Blackberry has suddenly stopped working. When
I would do a soft reset holding down Left Alt, Right Shift and Delete keys - simultaneously for a couple of seconds. That should clear anything that may be causing a memory issue...
Switching itself off... The above reset should resolve this, or show a bigger issue...
Crackling line though suggests a little more... Is this intermittent or on all calls?
Jun 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Blackberry Curve 8310 won't turn on
Slam the phone on a hard surface to get rid of dust in the connections. I suggest tile or cement.
May 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
My blackberry curve just says "SIM not provisioned:2"
you may need to have the OS reflash back into teh phone you can take it to your mobile carrier and have it done there.
May 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry  Pearl  8100 Logo
1,100 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
