Question about HP DesignJet 1050c plus InkJet Printer
System Error 04C300 00260000
Recently the paper and cartridges were changed and it was operating fine. I have not used the printer for a few days and now I find a error message. I have switch it off and on to no avail.
Can you please tell me what the error message means and how can I get it up and runnng again.
Could the 04c300 00260000 error be printheads fault
Posted on Oct 06, 2010
    Sergeant:
    Novelist:
  • 166 Answers
System Error 04CXX Try the following Steps to resolved an eror:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
Posted on Aug 21, 2008
My HP Photosmart C4400 keeps giving me the message, "The cartridge cradle cannot move. Please turn device power off. Check device for a paper jam or other obstruction." Two days ago, early in...
sure
or paper scraps in side blocking key sensors or other parts
clean all that chaff out first.
blow it and brush and pluck it all out.
there is nothing simple on printers, and 10000 types.
if fails to work after all that , it needs service.
Mar 16, 2017 | HP Photosmart C4400 series
Colour on glossy paper
First thing, use original Canon cartridges. that could be the source of your issue, as these days, printer companies resort to these kinda tricks to ensure that the customer only buys their products.
Next, make sure that you have selected the proper paper type and output quality under printer properties.
Should this not work, please post back so that we can assist you further. But remember, try with the original inks first, and not refilled or generic cartridges.
Jul 02, 2008 | Canon BubleJet i965 InkJet Printer
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
No paper light ligted even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
E5 and 2,114,0 errors on Canon MP160
Empty cartridges may cause this error. Here is the error code list for your printer
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
OFFICE JET 7410 ERROR
please do the following:
clean the cartridges and the printer contacts (cartridge contact on the printer) using a lint free cloth.
unplug the power chord from the back of the printer while the printer is on.... press and hold the # and 6 button on the printer and while holding them insert the power chord, wait for few seconds and release them.
check whether it is working fine or not, if not try with a different set of ink cartridges.
Feb 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP 5650 deskjet printer
Did you or one of your users have a paper jam recently and force the jam out of the printer? Because we've had a few 5650's do this after a jam. About 66% of the time this fixed it...
  • Removing the ink, unplugging the printer, moving the print head to the half way point, and starting the printer. If it resets at that point and lets you put the ink in, your usually gold. If it just stops and blinks again your not.
That said, I'm actually taking one apart that wasn't fixable this way right now. I think the problem may be something related to not recognizing if the cover is up/down, but still can't see why it happens or how that it is effected by the jam.
Oct 22, 2007 | HP DeskJet 5650 InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
804 people viewed this question
Ben Johnson
