Question about AcerPower 1000 (AP1000EA380M) PC Desktop
Acerpower 1000 - won't boot (or POST);
CD Rom LED light stuck on at power-up.
Started gradually, had to shut off power supply to beboot, now won't start at all. PLEASE HELP!!
  • 1 more comment
  • atalderfer Aug 31, 2008
    I am having the same problem. The computer will not turn on now. Only 1 year old.
  • acer sucks Sep 19, 2008
    Same here, Acer said sorry they won't fix it AGAIN! This is the 3rd MB in this pc.
  • oOiRoNiCoO Mar 05, 2009
    I seem to have the same problems as explained above (cd light and fan come on but nothing more) i have looked at the motherboard but i cannot see any visible signs of heat damage or of any blown capacitors. How noticable would it be if they had blown? and are you talking of the 2 basically under the cpu heatsink?
I had to start my acerpower 1000 four or five times. When it boots into windows, it lasts for about a minute, then shuts off.
When booting into safe mode, the PC will stay on forever. I would think a hardware problem would cause it to always shut off.
This is not a solution, but something I have observed about these machines.
Posted on Oct 23, 2008
  • frankvizza Oct 24, 2008
    HOW TO FIX THIS SYSTEM ---
    My friend got 20 of these systems in his business. Within 1 year, four of them failed. They would not power on or would shut off at will.
    I was asked to look at them to see if they could be salvaged. Here is what I found.
    On the motherboard, there are two 6.3v 1000uf capacitors that have been heat damaged by two nearby active devices with aluminum heat sinks. How to tell if you have this problem. On the other 6.3v 1000uf capacitors on the motherboard, the tops of the caps are very flat. On the damaged ones, the top of the cap is bowed outwards slightly.
    If you have this problem, DO NOT try to change them out unless you have experience in doing this!
    After I changed them out, the system powered up, did not shut off at will. Problem solved!!
    By the way, turn off this system when not using it. It will last longer since the problem is essentially heat related.
    To Acerpower 1000 manufacturers: You are welcome! Please change the design of the motherboard and move these capacitors out of the "heat field" of the two active devices.
You rock dude!!! I'm looking at those two blown capacitors exactly where you said they'd be. I think it is absolute stupidity for them to try and put a 31/2 inch HD in a box this size. I even found melting on the wires (which have black heat shield around them) that connect from the board to the front panel connectors. They've actually melted to the underside of the HD. Brilliant!
Posted on Nov 26, 2008
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
Mar 18, 2012 | Compaq CQ4010F Desktop PC (NY650AAABA)
Hp mini 311-1000nr won't boot from dos
Restart and press Del or F2 or F4 frequently for enter to bios setup.
select boot piority for cd rom and insert bootable cd and press f 10 for save changes,Now press enter for boot from cd rom .
Hope this helps ,
Let me know if you need more information Thanks
May 11, 2011 | HP Mini 1000 Netbook
AcerPower 1000 (AP1000EA380M) PC Desktop: i cannot install win xp on acer power 1000...
Hi! Try to go to bios menu via F2 or del while system is starting up.Go to sata operation, change IDE to AHCI or vice versa, save settings then try to reinstall os(win xp) again via booting to the disc (F12) and choose cd/dvd or odd...hope this helps...Cheers!!!
May 18, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
Help plesase, my computer won't past POST
Check the there is proper power supply is coming through the power supply. And also remove ur CMOS and Then check if it works or not
Apr 27, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
I have problems with my AcerPower 1000 with windows xp
heck the Cd, it sem it is bad and your rom can't read it, try and get another better Cd. good luck
Jun 05, 2009 | Microsoft Windows XP Professional for PC
AcerPower 1000 keeps shutting down
you mean the computer power off automaticaly.
check the all cable of mother board.
Jan 21, 2009 | AcerPower Sn PC Desktop
450 power supply
The cd may be bad, or if the power supply is just marginal, it may be failing when the cd motor spins up.
Jun 04, 2008 | Compaq (176763001) 120-Watt Power Supply
AcerPower F1 PC Desktop Problem
It could be a bad power supply. As far as I remember, this unit has a standard ATX 230 watt power supply. It should not be too hard to replace it. Its fairly straight-forward. Its a matter of removing the panel to access the connectors inside (make note of which comes from where) and unscrewing the power supply on the back of the unit. Reverse all actions to install new power supply. If you need more detailed help, reply to this post.
Apr 25, 2008 | AcerPower F1 PC Desktop
AcerPower 1000-EA380M No Video
open the cover,try to find jumper "c-mos clear",probably is green,or red. put it on,then power on the machine abaut 3 -5 sec.then shut it down. then put the jumper in prevoius position and start macine normaly.on screen you have a note "c-mos clear,enter setup......",enter set up and chose auto configuration,save and exit and everything is ok.
Feb 04, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
My cd player went out gradually
I don't do componant repairs but can supply replacement power boards. Contact me via ebay - fluffcat1
Nov 08, 2007 | Philips CDR770 CD Recorder
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
1,693 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
