Question about Whirlpool LER4634J Electric Dryer
Dryer not turning on at all
My dryer is not turning on at all. I relize i need to check the door switch, on switch and outlet (but they "appear" to be ok) but i was wondering if there wasn't a fuse somewhere on the dryer that i can more easily visually inspect before getting out the multimeter. If so, where would i find it? Thanks
  • 1 more comment
  • jason027 Aug 22, 2008
    ok - i think i located the thermal fuse. Stupid question but, when i check the fuse, if i don't get a current through it when i test with my multimeter, that means its bad right?? I did check the outlet, and the door swtich and all came up ok.
  • jason027 Sep 02, 2008
    I replaced the thermal fuse and all is working again. Thanks for everything! Now i just hope the reason for the fuse going doesn't show up again. Great site. Keep up the good work!
  • Anonymous Sep 06, 2008
    Where is the thermal fuse located
  • 5,911 Answers
There is no fuse that you can visually check on this dryer. The thermal fuse is a solid white plastic component that does not have a visual filament. If the model number you listed this under is correct, the thermal fuse is located in the rear of the dryer, mounted on the air blower housing. You can access it by removing the back panel of the dryer. It will be located on the left hand side of the dryer (facing from the rear with panel removed) adjacent to the operating thermostat on the blower fan housing. If you have verified the door switch, verified the voltage at the wall receptacle, and verified you don't have a breaker tripped somewhere, then the next logical step would be to perform a resistance check of the thermal fuse. This is not a resettable device and must be replaced if blown. Let me know if you need further assistance. I hope this helps you.
Posted on Aug 21, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 22, 2008
    My apologies Jason, I should have given you this link to assist you in my previous post:
    http://www.fixya.com/support/r385301-tho...
    This will give you some good advice on how to troubleshoot and what measurements you should get with a multimeter. In addition, it gives you some good advice on proper maintenance and how to prevent future problems.
    To answer your question, if you are talking about a resistance check, the thermal fuse should read close to a short (approx. 0 ohms). If it reads an open (inifinite reading on a mulitmeter) you have a blown fuse. As far as voltage checks across the fuse are concerned, a voltage reading actually indicates a bad fuse, while a reading of 0 VAC indicates the fuse is good.
    The reason: Voltage is the difference in potential between two points. With the fuse shorted (good fuse) there is no difference of potential between the two sides of the fuse. Thats why you get a 0 VAC reading. With the fuse open (bad fuse) there IS a difference in potential across both sides of the fuse, so your meter will indicate a voltage reading. This is often a point that the do-it-yourselfer confuses because they misunderstand what the multimeter readings are. I hope this does not confuse you. For simplicity reasons, this is why I recommend a simple resistance check with the dryer unplugged.
  • Jeff Rockwell
    Jeff Rockwell Sep 02, 2008
    The number one cause for thermal fuse, thermister, or thermal cutout problems is poor ventilation. A little routine dryer maintenance can go along way towards keeping some of these problems from reoccuring. Congrats on fixing the problem yourself! I hope I can be of assistance again if you need anything.
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
Get dryer to work, no instruction manual for Indesit Washer WDG 1195 W
What to check when your dryer won't start-
The wall outlet 240 volts:
The first thing to check when your Whirlpool dryer is not starting is the wall outlet to make sure that the dryer is getting the proper voltages. On an electric dryer there should be 240 and 120 volts present at the terminal block.
A blown fuse or tripped circuit breaker are one of the major causes why the dryer won't start. To check the voltage on an electric dryer you will need to use a multimeter.
The wall outlet 120 volts:
A gas dryer connects to a 120 volts wall outlet, and it is very easy to check the outlet. Disconnect the dryer and connect a hair blower or any other small appliance on the outlet.
If they work, then the problem must be on the dryer. If the don't work, check for a blown fuse or tripped circuit breaker. If the problem is bigger than that, have a license electrician check the house wiring. A bad wall outlet could be the reason why your Whirlpool dryer is not starting.
The thermal fuse:
The thermal fuse is use on an electric dryer as a safety devise to open the motor circuit if the operating thermostat fails to open at the preset temperature or if the motor draws too much amperage.
A blown thermal fuse could be the reason why your Whirlpool dryer is not starting. It is located behind the back panel on the dryer.
The door switch:
The door switch is another safety device use on the dryer. It is connected on the neutral line of the motor circuit. A door that is not closing properly or a bad door switch could be the reason why your Whirlpool dryer is not starting.
The push to start switch:
The push to start switch is use to start the motor. There are two types of switches. The older type switch is a solenoid operated door switch and the other one is a simple push to start switch.
A bad solenoid operated or regular push to start switch could be the cause why your Whirlpool dryer is not starting.
The timer:
The timer is the distribution center or the brain of the dryer. Inside of the timer is that the electricity gets routed to the different electrical parts in the dryer.
The timer has contact points, and the contact points wear or burn out depending on the amount of use. Contacts burnt inside of the timer, could prevent the dryer motor from starting..
The motor:
Also, the motor could be burnt bad. A motor that smells like rubber burning, makes growling noises, runs for a wile, the won't start until is cool down or a motor that runs fine, but the centrifugal switch is not making the right connections is a bad motor and must be replace.
So...as you could see, there are many parts that could be the reason why your Whirlpool dryer is not starting.
Feb 16, 2008 | Washing Machines
Ge 5 cycle automatic dryer
check the lid or door switch, open and close the door, when you close it have to make a click if not there you have your problem when the switch goes bad is like when you hace the dryer door open. Hope this help
Jan 29, 2014 | Dryers
Dryer has no power will not turn on
Is door shut good ? Check door switch push it in and see if you can hear it click. Check power at outlet then where it goes into the dryer. Check start switch and voltage coming out of the timer. Check voltage to motor. If voltage to motor you will need a motor.
Nov 11, 2013 | Whirlpool LER5636P Electric Dryer
I have an electric Kenmore dryer that wont turn on
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
Apr 16, 2010 | Kenmore Dryers
Dryer won't turn on. Have checked the outlet
hello, my whirlpool dryer wont turn on, we have check the electric comming in and the door button and the on (start) button too, do you know what else we can check ?
Mar 08, 2010 | GE Dryers
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Dryer won't turn on
have you checked the outlet? I had an outlet go bad and cause this problem for me.
Apr 03, 2009 | Kenmore Dryers
My admiral dryer LNC7753A71 just stopped working. Turning the timer only produces a clicking noise but all else appears dead. I checked the 240V outlet and its producing 240V and 120V on each side. The...
Your dryer is equipped with a thermal fuse located behind the drum seat on the heating coil.
http://www.applianceaid.com/la-1053.html
There are two white wires connected to the fuse. Pull those off and connect together. Your door light will come on if that is your problem. There might have been a problem that caused the fuse to blow. Check for kinked dryer hoses, dirty lint traps or anything that might have caused it to overheat. You must replace the fuse or you risk catching the dryer on fire.
May 05, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
