Hi You can test the door switch, if the door switch tests fine
then it is the control board that is bad and if the unit is too old then its
better replacing the unit completely as the control board will cost you around
same as new one. Hope this helps...please post back for further assistance. Daniel
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARRAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
